Question about Olympus FE-340 Digital Camera
When I press the power button the lens goes in and out a few times then the camera shuts off
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
My Canon camera turns it self off when I press the start button. the lens comes out & then the camera shuts down. When I restart it the lens retracts 3/4 & then comes right out & shuts down again. the lens...
hi, the camera must also be giving a lens error and must be making a whirring sound when turned on, hold the camera with camera off bang it with flat of hand , a few times , if this does not work , repeat it with camera on, even if this does not, when turning the camera on gently apply pressure on the front of the lens, do this just once , all the above fails , camera has to be service , lens unit may have to be changed
Aug 27, 2016 | Canon Cameras
When switching my camera on it just switches itself straight back off?
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Nov 06, 2010 | Kodak Easyshare V1233 12.1MP Digital...
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
Turn camera on, lens goes in and out then camera shuts off
You may try resetting the Camera to the original factory settings.
If the issue persists then service will be required.
Aug 27, 2009 | Panasonic Lumix® DMC-FS3 Digital Camera
Lens goes in and out three times when turning on or shutin off.
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is recommended.
Jun 15, 2009 | Sony Cameras
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Jammed camera
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again
Oct 19, 2007 | Samsung Digimax S800 Digital Camera
Olympus FE-340 Digital Camera Logo
20 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
