Question about GE Profile Harmony DPGT750GC Gas Dryer
Dryer is not getting any power. An its not the outlet.
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
How do I check for power to my dryer
You could plug something else, like a lamp, in the wall outlet and see if that gets power.
If the dryer requires a phase connection, that would be harder to test. Then you would need a volt meter to test the power outlet for proper voltage. That's a little dangerous though, unless you have some experience with power line testing.
Hope this helps.
Feb 04, 2015 | Whirlpool LEW0050PQ 3.8 Cu. Ft. Electric...
Dryer 220 Breaker Repeatedly Tripping
Check all your wires again make sure you have a solid connection also your dryer plug has to fit really good in to the outlet not loose
Don't forget always turn off your power before work
Apr 01, 2014 | Electrical Supplies
We had an older dryer, and it got to the point that it would run a couple minutes, then quit. We bought a brand new Kenmore Elite dryer... model 110.64994300... and it does the same thing. We thought it...
if you have a volt meter u can check power coming in should b 220 volt put one meter leave on black wire an the other on red wire meter should read 220 volt an if u go front black to white it should read 110 votl u could have a bad outlet dose outlet look like it been burn if best if you dont know how read meter to just call your appliance repair service ok be safe an turn power off to dry b4 you start test it out ok hope this help you out
Jun 02, 2017 | Kenmore 64992 Electric Dryer
My wife started the dryer the other night and 15 min into the cycle we could smell something burning.we discovered that the electrical outlet got so hot that the dryer plug and wall outlet were melting.i...
The problem was not in the dryer, but it was a loose wire in the plug or the outlet...I have seen this happen many times.. the wire gets loose and then because of the poor connection it heats up and starts a fire...
Replace the outlet AND the plug!!
The dryer pulls a lot of current but it is not the problem...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 23, 2010 | Hotpoint NVLR333EE Dryer
Dryer will not turn on. Checked outlet with
unplug dryer and take back panel off. plug back in. use caution your working with 220v. get a reading on power cord where it connects to dryer. if your good there look for a micro fuse, two small wires connected to it very small component. sounds like you have a bad power cord or power surge popped micro fuse. good luck and be safe!!
Jan 09, 2010 | Magic Chef CYE3005AYW Electric Dryer
My dryer would not run when I pulled the knob to start. I took the power cord out of the wall outlet. When I replace the cord into the outlet and pulled the knob the outlet sparked.
you most likely have a loose wire inside that wall outlet. use an extension cord to plug your dryer into another outlet that you know works properly and see it your dryer will work on that power source. If it does, just replace the receptacle in that wall outlet. If the dryer still wont run, then you know you have a problem with the dryer itself. If that is the case get back and I can talk you through solving that problem also.
Oct 25, 2009 | Dryers
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
GE Profile Harmony DPGT750GC Gas Dryer Logo
37 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
