Question about Sony Playstation 3 (PS3) Console
My ps3 shut off and I tried to turn it on again and it beeped 3 times, the power button went red,yellow and blue then shut down. After all that it still flashes red and does not turn on. I also have mw2 stuck in the ps3. Help me or tell me that its broke
Had the same problem but a different disc. This is what i did that got the disc out but I am still having same problem with system. First cut the power switch on the back panel to OFF position. then hold the EJECT button down and while holdiing this button down turn the power switch to ON position. I had to do this a couple of times to retrieve the disc but I did retrieve it. Now if I can figure out how to solve the other issues all will be good.Hope this works for you.
Posted on Aug 26, 2010
    Problem Solver:
  • 11 Answers
Make sure that your PS3 is not put in an air tight space, direct sunlight, or heated room where it overheats. Put it in an open space, and make sure that there's sufficient air flow. Otherwise, You'll get the 'yellow light of death' Hope this helps.
Posted on Aug 24, 2010
My ps3 goes to boot up an then shuts down beeps three times shows a blue light then a quick yellow light then goes to blinkin red light
You could try pressing the power button and holding it down. You will hear the first beep when you press it but hold it down until it beeps a second time it will take 5 to 10 seconds. This will reset the console and it may boot up. If this does not work you can go to www.us.playstation.com and check the user knowledgebase and/or support for a solution.
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
I turn on and it goes green the blue then yellow then red flashing..nothing else? I have turned off for a few days and same thing just continue's. Not working at all?
Restore File System. If that do not work try Restore PS3 System.
Follow this guide. Read carefully.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
Ps3 won't turn on just beeps then switches off
Please check if you get a yellow or red light flash and how many times does the ps3 beep before it shuts down.
If you get a Yellow Light, reason below:
If the hard-drive fails on the PS3 you may get a solid yellow led, The yellow light will show if the console is overheating as well, but the console shuts down so you don't it for long.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then it is suggested to send your PS3 for repairs to Sony Customer Support
Let me know of this helped and please take time to rate my solution.
Wishing you Happy Holidays and Happy Gaming
Regards
Kreative Geek
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
Hi, my ps3 shutting down when I turne on the power
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 27, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Try to turn on ps3 wont go on
restart the system...
1.take all discs out
2.turn the system off at the back then on again
it should now just be red
3.hold down the standby button untill it beeps for 4 times then quickly take ure finger off it may have changed channels eg hdmi 1 -2 or av then click option 3 and it will resolve all corruptions.
If this advice doesn work ust phone sony they know everything, googd luck
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 Green then Yellow flash then blinking red
or you can try to get your money back if you hve a receit i say give it bak and get you a new one. or see if you can find one ebay or game stores
Jun 01, 2009 | Sony Playstation 3 (PS3) Console
My PS3 wont turn on...
Try holding down on the on button till it resets the settings, that may turn it on
May 05, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
