Question about Brother MFC 420CN All-In-One InkJet Printer
Change change ink cartage comes up and want print.I refiled the cartage from a kit...it worked before when i filled it ...
    Sergeant:
  • 203 Answers
Refil Kits dont always work, you made need to buy proper ink cartridges.
Posted on Aug 24, 2010
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
It will only scan not print
If you refill you Ink Cartage on this Please make sure the Ink is primed. If you touch a paper towel to the bottom of the ink cartage and the tale stays dry It is the cartage.
If that is ok Make sure that the door and the contact(If you can see it) Is closed and in good shape
Jun 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
How to refill ink in hp blck cartridge
  • Purchase an ink refill kit at an office supply store. (Staples, Walmart, and Costco all carry this inexpensive kit. It usually costs about half the price of an average printer cartridge.)
  • Gather your kit, a roll of paper towels, and some clear scotch tape together on a large flat working surface, a table or desk.
  • 3Remove the empty cartridge from your printer. (Remember to close your printer lid or door while you are working.)
  • 4Cover your hands with a pair of disposable plastic gloves while you work with the messy ink.
  • 5Take a paper towel and fold it in half twice. Work over the paper towel to catch any leaking ink.
  • 6Place the empty cartridge on it.
  • 7Read the instruction manual included with the refill kit to learn how to refill your particular type of cartridge. (The following instructions are just a general guide).
  • 8Locate the fill holes on the top of the cartridge. The depressions can be felt by rubbing your finger across the label.
  • 9Use a sharp pencil to pierce the refill holes in the top of the ink cartridge. (Correct places can also be found in the kit instructions).
  • 10In addition to black, there are three colors of ink: magenta, cyan, and yellow. Follow the kit instructions on which hole to insert each color OR push a toothpick into the holes to identify the colours as markings on the printer cartridge are sometimes there to fool you into putting the wrong colours into the cartridge ink chambers.
  • 11Insert the long needle on the refill ink bottle into the correct hole.
  • 12Slowly, add the ink. Carefully watch to be sure that you do not over-fill.
  • 13Stop quickly as soon as you see a bit of ink oozing out of the hole. Without letting go of the bottle, slowly release the air, sucking a little ink back out of the ink cartridge, before you remove the needle completely.
  • 14Carefully daub the cartridge contacts on the paper towel, you should see a splotch of the ink leaking out onto the paper towel.
  • 15Cover the hole with a small piece of clear scotch tape. (This works better than the seal dots included in the kit.) Make sure that no ink is leaking out of the top holes. (That's where the clear tape comes in handy.) Be careful not to cross contaminate the colors.
  • 16Repeat steps 11-15 for each ink color.
  • 17After you have refilled all three colors, carefully blot (don't wipe or rub) the cartridge printhead on a folded piece of paper towel. You may need to do this several times. Do this until it stops bleeding and you see an even stripe of three colors showing up on the towel.
  • 18If the blot shows the colors either faded or not at all, blot on wet paper towel and again on dry, to get the ink flowing.
  • 19Replace the ink cartridge into the printer. Never, ever install a leaking print cartridge.
  • 20Immediately print something, anything, just to get the ink flowing. Print several test pages, preferable photos with a lot of different colors.
  • 21Follow the cleaning or priming cycles for your specific printer.
  • May 25, 2010 | Office Equipment & Supplies
    Ink cartrages lexmark ,,
    Hi there
    Lexmarks cartirdges not like to be refilled they not work the chip on the inks will still say emty after you refill them.
    If you want to try to fill them.
    All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
    http://www.youtube.com/watch?v=pnCPB9Clk5c
    All the best Pineworks
    Mar 07, 2010 | Lexmark X4650 InkJet Printer
    My printer is printing yellow only
    hi, i think the other ink is finished in your printer cartage. i also have the same problem and then i buy a ink refil kit and then fill the cartage with blue and mergenta colour and then it working fine. I suggest while filling the cartage please don't remove the slip, just fill it using injection.
    Sep 04, 2009 | HP Color LaserJet 2600n Printer
    Can't Fill ink in X2650 Lexmark
    If your looking for cheap ink, try buying a more expensive printer as ink for the expensive printers are relatively cheaper. I also tried refilling the inks for my printer but to no avail, it simply leaked out the bottom making a big mess
    Jun 08, 2009 | Lexmark X2650 All-In-One InkJet Printer
    Check print cartridge error
    Set the properties to print on HP paper. This usually solves the problems
    Mar 09, 2009 | HP DeskJet 3745 Printer
    Wrong colors when printing on photo paper
    yha way not
    if you worry about wrong colors
    it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
    Dec 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
    Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
    Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
    Brother MFC 420CN All-In-One InkJet Printer Logo
    62 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
