Question about LG Heating & Cooling
HVAC AIRCONDITIONER THE COMPRESSOR RUN BUT TRIP
  • Patrick Worley
    Patrick Worley Aug 25, 2010
    Is it the compressor only that trips and then comes on later by itself ?
    President:
  • 3,074 Answers
Check the fan motor
Posted on Aug 25, 2010
Why does my Dometic caravan airconditioner turn itself off after a few hours and won't restart for hours later?
There is a temperature controller safety switch on the compressor under the plastic cover for the wire connections. You need to determine the reason it is tripping first, so you can correctly diagnose the problem. If the compressor is indeed running hot there is probably a lack of freon or an internal motor winding problem. If the compressor seems to be at a normal temperature(High side of warm but not burning hot)then look to replace the temperature switch.
Jul 03, 2014 | Cars & Trucks
Breaker keeps tripping on generator when I turn on ac in travel trailer
4KW is marginal for HVAC compressor. Breakers get weak with time. Assuming th gen is running properly and the correct voltage is available. A HVAC unit can take 6 times the start current than it takes to run, so it is possible the inrush is too much
Sep 02, 2013 | Makita 9 Hp 4,300 Watt Portable Generator...
I HAVE XB10 HVAC SYSTEM TRIPS BREAKER
could need a start assist for compressor or could be weak breaker
Dec 03, 2012 | Heating & Cooling
My 06e run high amprage anf trips my breaker
Hi jc escamilla
Check and repair your compressor unloader valves...
If they are stuck,broken,etc...then they will cause the problem you are experiancing.
Also check you oil level, low oil could be the cause also.
Please rate me
Bud
Oct 19, 2012 | Carrier 30 Ton Hvac Air Compressor (brand...
Rv airconditioner trips breaker
Does it trip when fan only , or when compressor for cool cuts in? Sounds like capacitor perhaps . Get back to me with model number, and whether it's a ducted system, or blows out at ceiling assembly.
Apr 02, 2012 | Dometic Rooftop RV Air Conditioner
My whirlpool window air conditioner' compressor
Sounds like a bit of refrigerant leaked out and it is freezing up or at least running too cold...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Whirlpool Heating & Cooling
I have an lg split system airconditioner. The unit starts up fine and runs for a few minutes. After a few minutes it trips the circuit breaker. Could you tell me what causes this? Thank you
Sounds like an electrical problem.. or the compressor is beginning to fail. Check the wiring connections on top of the compressor for burning etc ... If OK, the compressor may be shorted out.
Make sure the power has been switched OFF before any testing is done.. Usually an LG will show a fault code on the display on the internal unit but a dead short on the comp will happen to fast for this to occur. One way to isolate a compressor fault is to disconnect it.. If the unit runs ( fans etc) with the comp disconnected and does not trip the breaker , then you have narrowed down what the fault is.
Jul 14, 2011 | Heating & Cooling
I'm looking for an enigma split system airconditioner manual-I have an error message E5 with no compressor activity
E5 Communication errorbetween outdoor and indoor. Check output (call) from your indoor unit to out door unit by Volts meter. If no power in out door, you have to check setting of temp whether it's 23 and less than that and also mode in "Cool".
If power is there in out door and fan only running means compressor is tripped by overheated
Dec 16, 2010 | Heating & Cooling
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Flooded floorboards and iffy airconditioner in 01 Galant
the heater core lines are under the dash and when it starts leak i will flood the floor board. does the ac shut down even if you are running it on recirculate and on fresh air. it may be the compressor clutch. if that hasn't been replaced yet.
Aug 18, 2008 | 2002 Mitsubishi Galant
Heating & Cooling Logo
19 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
