Question about Foxconn G33M Socket LGA775 motherboard
Wont boot just get 3 beeps pause 3 beeps ect......
    Sergeant:
  • 203 Answers
Hope this link helps, please leave Thumbs up if it does thank you.
http://www.5starsupport.com/info/beep_codes.htm
Posted on Aug 24, 2010
Computer will not boot up
3 beeps points to ram problem, try removing the memory and putting it back, sometimes it'S just a bad contact... else, try new memory.
May 22, 2014 | Gateway DX4870 Desktop DX4870-UM20P
Need manual for pc chips a13g+v3.0
- If 3 short beeps than DIMM memory not properly inserted or memory failure
- If 1 long beep and 8 short beeps than VGA not detected
Jan 10, 2014 | Pcchips PC CHIPS A13G V3.0 Socket AM2/...
Computer will not boot. 3 beeps pause 3 beeps pause ........
Remove the RAM modules and clean the gold fingered connectors with tissue paper. Clean the RAM Slots carefully with a vacuum cleaner. Then reinstall the RAM modules.
Power on the system.
Next to try is all power and data connections!
Take care!
damnor01
Aug 30, 2011 | ASUS Computers & Internet
When I power on screen shows Compaq boot screen then flashes to black then back to boot up screen. I cannot go any further. Please help.
Regarding with problem basically some part their failed. You need to check the RAM and HDD. Reset the CMOS battery remove the CMOS jamper with in 5 seconds and put it back. If you loss the first try you also recovery, to recover load the windows CD and boot up repair the windows until it is done. Good luck!
Regards
nicole
Oct 03, 2009 | Compaq Presario R3000 Notebook
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
My computer beeps
the memory might be loosed clean the memory contacts using eraser then reinsert it properly
Sep 22, 2008 | Computers & Internet
Dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
Foxconn G33M Socket LGA775 motherboard Logo
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
