Question about Hitachi 43FDX01B TV
My picture in my television is like shadow box size but not a normal shadow box program. When the t.v. is bumped the picture goes to normal then back to small , What is obviously loose?
  • Hitachi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Posted on Aug 28, 2010
How do we get shows (programs) to cover the whole screen on our tv
You can access either through the TV's remote, or the cable box remote picture settings for choosing picture size (i.e., normal, wide, stretch, wide zoom, etc.).
Oct 20, 2014 | Televison & Video
Edge to edge screen bumping to get more space on 5100 dell
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 17, 2012 | Dell Inspiron 5100 Laptop
I have a 26" fluid plasma T.V. I did not recieve
If this is the remote that goes with this television, and this is not a universal remote or one for a different model it does not need to be programmed. There is often a button on the remote that adjusts the picture size. It may be wide, format, view mode, aspect, zoom, and etc. This option may also be in the menu if there is no specific button for this task. However there are reasons that the screen size will not adjust even when pressing the proper button.
Now if you are using a cable box or satellite tv receiver there may be a button on your cable or satellite remote that will adjust the picture size. It is usually hdzoom # on the cable remote and format or aspect on the satellite remote. Picture format may also be in the cable box or satellite tv receiver's menu options.
However if you are connecting with an over the air antenna or direct cable and you are watching a high definition program this sometimes happens. You will not be able to adjust the screen size. Also if you are using a cable box or satellite tv receiver and it is set at a higher resolution than what the television is designed to display then this will happen and there will be no way to adjust the picture size. The cable box or satellite tv receiver could also be connected to your television with a coaxial cable to the rf/tv input. If you are in that input rather than the av, component, or hdmi input then this can happen.
Apr 27, 2011 | Televison & Video
I think my kids have pushed a button and the screen is got borders on the side and picture condenssed
If you have cable or satellite and a cable box or satellite box it is probably its remote. Look for the hd zoom # button or format button or aspect button to change the picture size.
Someone may have also changed the input on the television. Your cable or satellite box might be connected to two different inputs on your television so you have to make sure the right television input has been chosen with the television remote.
There should be a zoom, view mode, aspect or etc button or setting on your television that adjusts picture size.
Some television programs just broadcast like that and there is nothing you can do while that particular program is on to increase the picture size.
Oct 28, 2010 | Panasonic Televison & Video
Picture Size
Keep in mind that not all programs and show are in widescreen format. When set to normal, you will get those black bars on the sides because the program is sized for the older TV's. Some TV's will have a zoom option, but that will cut off some of the top and the bottom of your picture.
Until everything goes widescreen, you are stuck in normal with those black bars or widescreen with the fat people.
I hate distortion in my TV image, so I am perfectly fine with my TV on normal.
Good luck.
Jul 14, 2010 | Philips Magnavox 42MF521D/37 Television
I cant adjust my picture size to normal on my Sony Wega 51" TV
the screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Apr 21, 2009 | Sony KP-51WS520 51" Rear Projection...
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Hit wrong TV remote button, knocked out HD programming
You have multiple issues. The shadows are likely convergence IC solder connections breaking or the ICs actually failing. If you can bump the tv to get it to re-align, it just needs resoldering. If it doesn't snap back, it needs new ICs. The channel issue is less common and could be a number of things. You may want need to just autoprogram again to, but may have a fluid leak issue. You can unplug the tv and remove the back panel to inspect for fluid on the signal board (board with tuners, where cable plugs in).. DON'T touch the fluid, highly toxic stuff. Take a bright light and see if any drops have made it down to the board. If so, the severity of the leak will determine the repairablity. Try using a VCR or cable box to bypass this problem if no fluid leaked, that is the best (cheapest) way around it.
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
The picture is too big for my screen
press zoom on the remote control to get the normal size
Dec 24, 2007 | Toshiba 35A44 35" TV
Television picture gets larger
Your problem most likely is in your high voltage circuit, and the 160 volt radial lead capacitor is probably gone high ESR or changed in capacitence, this usually happens during bright sceens or sceen change.
May 24, 2007 | Panasonic PT-51HX40 51" Rear Projection...
Hitachi 43FDX01B TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
