I want to put this board into a different case, but I can't tell which connections to use for the power switch, power LED, and HDD LED! Is there a wiring diagram available for this board?
  • Ytee
    Ytee Aug 24, 2010
    make and model of Motherboard please.
  • Ytee
    Ytee Aug 24, 2010
    make and model of the Motherboard please.
    Guru:
  • 302 Answers
You should look into its manual, there is aslways is given a diagram which shows the orientation of the Pins.
Posted on Aug 25, 2010
Dont seem to have enough front panel pins for all my case wires
Hi Greeneyedbj,
What kind of I/O connectors are you looking for *********** board sir?
The image above has the following for your I/O connectors.
1. Three usb headers up to 6 additional devices, most casing can support 2-4 pins. 2. Front Audio Connector. 3. Front Panel Connector. Power Sw, Reset Sw, Powed Led, HDD Led
Branded casing has the following I/O connectors.
1. Esata 2. Firewire (Dont use the USB headers, firewire use a different pin-layout) 3. Chassis Intrusion Alarm Header.
Hopefully this information helps.
You can ask for more help.
Thank you for using FixYa.
Sep 23, 2011 | Foxconn A74ML-K Motherboard AMD Socket...
I have a GA-81865GME-775-RH motherboard, which i put into my box, made all the connections, but have no power once I switch the box on. I suspect it has something to do with the wiring loom running from...
Hello julian_ad681
I will tell you how wire your case front panel, but before that lets test the motherboard to make sure the problem is not the board itself.
Remove all the wire connections to the front panel.
Turn the power on and with a small screw driver or anything that is metal short (touch) the two pins that are the PWR SW. (look at the list of pins I have put at the end)
If the computer turns on then it means the board is ok.
The following information is also availabe in the motherboard manual available from the gogabyte web site download section
On the motherboard next to the battery is the front panel header pins. it looks like
0 0 0 0 0 0 0 0 i also write them as numbers as well to make it easy for you)
0 0 0 0 0
1 2 3 4 0 0 0 0
5 6 7 8
1 and 2 are message LED. you don't need any connection to this.
3 and 4 are the power switch connections no polarity, just connect the wires
5 and 6 are the hard disk LED. 5 is the positive side (usually red)
7 and 8 are the reset switch. no polarity, just connect the wires.
Next to the message LED there is a three pin connection. This is for the power LED.
hope this has helped you.
please leave comment, vote if the helped
Feb 10, 2011 | Intel Motherboard
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
Hi Expert, I am switching Foxconn 661M03-G-6L from my old PC casing to a new casing but forgot to lable the pin connections for the following: Power Switch, Power LED, HDD LED, Reset Switch and Speakers ...
You need the manual which you can get here for your board, and download it at the bottom of the page, once you have the manual, then you should see the connections. The other way to tell is to look closely on the board, it might say which goes where right by the connection on the board, and then the wires should say on them what they are, and you can put them where the board says, if you have that on your board.
http://www.foxconnsupport.com/download.aspx?models=en-us0000280&category=C000000001&series=en-us0000001&keywords=&sort=Motherboard%20Manual
Dec 01, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
My motherboard out of a dell optiplex gx260 the board it self is part number ASSY-3M537, I want to put it in a atx case I am worried it won't work. on the board I don't see how to hook up the power switch...
This should be the front panel header configuration of that particular motherboard.
6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Regards.
Jul 28, 2009 | Dell (E210882) Motherboard
I need to know what colored wires go where on my customers PC hdd led/ power sw/ and power led
the only reason to have removed them was to switch the board or put the board in a new case..if you put a new board the new board is what you have to go by, look in the book, or take the number off the motherboard and go to yahoo and type in schematic for xxxxx board.
DO NOT go by emachine model as its worthless, too many models have different hardware.
This is all basic repair 101, how do you have customers? lol
Apr 24, 2009 | E-Machines W4685 PC Desktop
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Power and reset switch and hdd led layout on P4Vmm2 mother board
[10][ 9] Pin 1 = +HDD pin 3 = -HDD LED
[ 8][ 7] Pin 2 = + POWER pin 4 = - power LED (SPD)
[ 6][ 5] Pins 5 & 7 = reset
[ 4][ 3] Pins 6 & 8 = Power switch
[ 2][ 1]
Hope you find this Useful
Dave
Nov 19, 2008 | EliteGroup P4VMM2 Motherboard
New installation of mother board
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
Oct 05, 2007 | Select Brands System on board CPU / VIDEO/...
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
Computers & Internet Logo
David Payne
David Payne
