Question about Kenmore 72055 Air Conditioner
My airconditioner makes a nose like ther could be some water in it. what is it and how can i fix it?
    Genius:
  • 1,400 Answers
Hello
Some air conditoners use the water they extract from the home to cool the condenser outside.This may sound like a splashing sound,made by the fan outside splashing the water on the condensor.
You may also want to check your dran hole outside under the unit for any **** that may have it clogged.
Posted on Aug 24, 2010
I have a tadiran carrier airconditioner that is blowing air but is not cooling. When I turn the airconditioner off I get an error message 03. how can I fix the air conditioner?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. For assistance check us out at Tamarac Ac Company
May 27, 2016 | Heating & Cooling
Does anyone know the quantities for making your own nasal saline spray? The ones in the shop are so expensive?
Try this recipe for a saline irrigation spray;
- Mix 1/4 teaspoon of salt and 1/4 teaspoon of baking powder into 8oz of warm water.
- Use a bulb syringe to squirt water into the nose.
- Lean over the sink and hold one side of your nose closed. Squirt water into it and let it drain out, then blow your nose.
Feb 18, 2013 | Health & Beauty
The pump makes all the right noises but no water comes out just a bit of stream?
somewhere ther is an obstruction and water does not come out, bring to service, do not attempt to fix yourself or can occour bigger damages.
Sep 12, 2011 | Ariete Cafe Retro Espresso Machine
1997 audi a4 airconditioner refill
You need to find the service port, on the left of the engine. There should be a chrome hose over ther where you can get your coolants refill screwed on.
Feb 06, 2011 | 1996 Audi A4
How to fix water pouring out of evaporative airconditioner?
look for disconnected water distribution pipes. check the condition of filters. clean if required. some will always drip of the sides a little due to poor design
Dec 05, 2010 | AdobeAir Mobile Swamp Evaporative Air...
My airconditioner is leaking how can i darin the
fix ya says service is FREE yet they ask fro credit card information
Jul 20, 2010 | Danby Portable Air Conditioner
Polaris 380 stand on nose while on will not move off
There are several things that you can check on these automatic pool cleaners to try and correct this problem. First, make sure that the filter bag is not full. A weighed down bad can cause the cleaner to tip onto the nose. If there is water in the head float, you will need to replace it. Make sure your hose floats are spaced correctly so that they are not causing the cleaner to float incorrectly.
May 17, 2010 | Polaris 380 In Ground Pool Cleaner
Water on driverside.
If you get under the passender side and look up, you can see the underside of the blower housing mounted on the fire wall. Ther is a rubber drain that looks like a duck bill. o. squeeze it like a coin purse and it will open. Watch out for water and scum.. You may be able to reach it over the right fender reaching under the blower housibg. The blower is supposed to keep it clear but it takes a set. Do not wedge it open or it will permit exhaust and road dirt into th passenger compartment. Good Luck
Jul 04, 2009 | 2000 Mitsubishi Galant
Airconditioner unit on my RV will not run.
Check to see if you have the proper voltage to the air conditioner and check your breaker.The clicking you are probably hearing is the thermostat opening and closing when you turn it up or down.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
DeLonghi portable airconditioner leaking water
nbenz ,
Welcome to fixya.
I'm Huuum and happy to assist you,
Portable units are supposed to spray the water on to the hot compressor an evaporate the water!
If it is only 3 weeks old ,you have a 1 year warranty. call service and let them fix it for !
Please remember to leave a rating before you go!
Thank you
Aug 26, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Kenmore 72055 Air Conditioner Logo
85 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
