Question about Sony Cyber-shot DSC-W30 Digital Camera
When i turn on my sony cyber shot camera makes a weird high pitched beep, when its at 1.0 zoom its blurry but every time i try to adust it it gets worse. when i zoom in it become clearer but still is blurry.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Hi i turn the camera on and have a blurry screen
Zoom motor in lens assembly is jammed and you need to replace complete lens assembly. DSC-T1 is an old camera so oes not worth to repair.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Blurry pictures
This is the problem of the ZOOM in your camera. Its alignment is disturb by you. Your camera must have fallen down or some one has pressed the ZOOM from front when it was open. The solution is to get repaired at your nearest SONY service center.
Apr 24, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony cyber-shot dsc-w200 taking blurry pictures in auto mode...
Its due to slow shutter speed setting.
If you want to take moving object picture, set high speed shutter, there would an icon of golf stick that is for moving object pictures.
Mar 23, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Auto focus
Make sure the macro funcion is off sometimes I forget to turn it off and when I try to take a normal picture it has a bad time focusing.
Jun 25, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cyber-Shot Dsc-W70
Hi
You probably have a faulty lens unit. You can make sure of this by checking that the spaces between the two rings that extend forward at switch on has the same distance between each other.
If it is not the case, your lens is damaged and needs to be replaced.
It normally costs about 1/3 the price of the camera, so it should still be worth replacing.
Bear in mind though that only Sony Service Centres can help you as the y need to setup the new lens adjustments with Sony specific software.
Hope this helps.
Mar 09, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Zoom not operating
hey there same thing happened to me, solution go to setup button where it says camera go down to digital zoom turn to on,
then go to setup 1 where it says conversion lens, turn to off solved my problem
hope this helps you.
May 30, 2006 | Sony Cyber-Shot DSC-S85 Digital Camera
Sony Cyber-shot DSC-W30 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
