Question about Refrigerators
Water dripping inside fridge - Refrigerators
  • 828 Answers
Check the freezer compartment for snow on back wall or base, If it is a frost free unit it may have a frozen cooling coil which would stop air circulation. Condensed water can be cause by same problem.
Posted on May 05, 2008
A slow drip in water dispenser
This sounds like a sticking solenoid valve. When you depress the lever for you water dispenser it activates a valve, usually at the bottom back of the fridge. It might look something like this:
25380372-1h1xuof4er41rm4qkikzo3jl-4-0.jpg Sometimes they just burn out and stop working or the seal inside fails sometimes from particulates in the water. Some people put a pre-filter on the water hose that attaches to the fridge just in case. If you have a water filter inside your fridge this does not protect the solenoid. They are next to impossible to repair so a replacement is needed. Just go to Amazon or eReplacement parts and search for your fridge model number with the search terms "water dispenser solenoid". If you are mechanically inclined you can replace yourself or get an appliance tech to do it. It's a 15 minute job.
Jan 23, 2015 | Refrigerators
My Westinghouse fridge freezer, model WSE6100SF, was affected by a power cut lasting 3 days. It now smells, but not inside. Is there a drip tray under the fridge that collects the water?
yes there is but most are not removeable.... remove the cover in the rear of the fridge, the pan is located around the fan motor that's underneath the fridge... I would try pinesol, bleach or odoban to kill the smell..... good luck
Oct 09, 2014 | Westinghouse Refrigerators
I have water dripping down the back panel inside the fridge-it is constant. I wipe down the inside back wall, but hours later the water is back. The fridge appears to have a "channel" for this water
with out knowing name brand an model# i would say it sounds like there is a drain tube missing from the upper patr or freezwr area to the drain hole at the rear bottom . there is a drain pan under the refridge which catches this water then it evarperates. it also cab that the proper drain is pluged or blocked with algie which is comon try a little bleach to clean out the drain area
Nov 15, 2012 | Liebherr Refrigerators
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
I have water dripping inside the fridge. the pan
You can clear the drain by removing the bottom drawer , you will see the drain hole,you can use a vacuum to **** it out or a flexible wire to push through it.
Aug 02, 2009 | Refrigerators
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
Dripping water inside fridge. Can't find drain hose
at the rear of the fridge unit there is a hole, normally at the bottom of a shallow "v" shape. there should be a plastic insert in it to clear any blockages, just wiggle it a bit. failing that a pipe cleaner will do the same.
May 02, 2009 | Refrigerators
Water coming out of the inside bCK OF MY FRIDGE
your drain hole is clogged needs to be thawed and cleaned out
Mar 18, 2009 | Refrigerators
Refrigerators Logo
623 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
