Question about Refrigerators
I have water dispenser model # PWD885W-1 now its no cooling.Only hot water is working.
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Water dispenser not working. Model 54616.
ok i owuld look at the resevour tank and take a hair drier aand heat up the oiutlet till the water flows again.
Posted on Jan 02, 2009
SOURCE: Polar Premium water dispenser in not cooling / Model # PWD885-1
Sea breeze... The link is no good...
Posted on Jun 02, 2009
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
hth
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
MY HAMILTON BEACH WATER DISPENSER MODEL 87307 SERIES A1360CT WILL HEAT BUT NOT COOL THE WATER.
The heating and cooling sections are separate..these are not known to last very long. Sorry. (check the switches though - does the indicater light come on?)
Apr 21, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Refrigerators Logo
283 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
