Question about KitchenAid Ovens
Right side of burners spark but do not light - KitchenAid Ovens
  • 346 Answers
Probably the orifices or burners are clogged with food particles or soot.
You can remove the orifices and clean them, check your owner's manual for service procedures.
Probably just have to lift up the hood, they usually pop right off.
Posted on Aug 24, 2010
Right side burner will not ignite. Pilot flame is on.
Hello Paul;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number or your range. This is located on a metal tag either on the face of the oven after you open the door, or on the side of the door.
Each burner probably has a individual flow control valve to adjust the flame. This is a low probably, but still could be the problem.
Let's assume you can light the bad burner with a match:
You either have individual spark ignitors at each burner, or a multi-spark module in the upper left top back of your range. This controls all 4 burners.
Go into the following website, put in your model number and find your individual burner ignitor or the spark module. Record the part number and going into the web and search the part. Do not purchase from Sears unless you want to pay 2 or 3 times the price. Also, consider used parts.
Water Filters Lawn Garden Appliance Parts
This is a easy fix if you have basic tools. Turn the gas supply off. Then turn on the burners to bleed the system from gas. Then kill the power to the range - circuit breaker or electrical cord before you begin the work.
Feb 28, 2016 | Ovens
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
My Whirlpool kitchen Range is Model # SF 3300 EK40, and the left side Igniter (IGNTR Surf) no longer sparks when either of the left side top burners are turned on. Instead, the right side Igniter sparks,...
Hi
You are right it is the igniter that is bad and should be replaced. Please check this video on how to replace it:
Hope this helps...please post back for further assistance.
Daniel
Feb 14, 2011 | Whirlpool Ovens
Hi, I replaced the right side ignitor module and now the ignitors spark vigorously and the burners light but the ignitors won't spot sparking and sometimes keep sparking several seconds after I turn off...
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
thanks.keep updated and please do accept the solution.
Sep 18, 2009 | Viking 30" Professional Select Built-in...
VDSC 365-40, Suspected right side ignitor box bad. Repairman came, obviously didn't know Viking, tore into unit and confirmed bad ignitor box. Estimated $450 to repair. I put in new box myself. Works...
You have to identify the thermocouple by the flame. Some units run sparks constantly to insure that tha flame stays lit. If you see the thermocouple bulb by the flame it is bad and needs replaced (he may have bypassed it also let me know)
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m10110_viking_primer_2005.pdf
It would be helpful if you have a multi meter. Sorry you are having trouble with the repair man. I hope I can talk you through this but if he has made a mess it could be 10 times more work for you. Txtooltime@aol.com
Sep 02, 2009 | Viking 30" Professional Select Built-in...
First two burners, now all burners...
You have a defective spark module. This is a device which breaks down the 120 incoming volts to a 12 volt spark to ignite the burners. Replace module and problem should be solved.
Sep 01, 2009 | Jenn-Air JJW8530C Expressions Collection...
One or more igniters are trying to light burners that aren't turned on .One burner is on. The other post on this never got answered properly.
When you turn the burner dial, all igniters spark. Most brands work this way. The dial activates all igniters to spark but only opens the gas valve attached to that dial.
Do you mean that they continue to spark even when you are not trying to light the stove?
Jul 28, 2009 | Jenn-Air JJW8530C Expressions Collection...
Gas Burner spark on other location
When you turn a burner to the light position, all burners should spark. If one is not, clean burner head area where the burner is not sparking. (dirty from boil overs)
Sep 02, 2008 | GE JGRP17 Gas Single Oven
Ovens Logo
32 people viewed this question
Top KitchenAid Ovens Experts
ashburton
jdthefixer
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
