Replace old tv antenna with a new one.
I live in a unit that is 30 or more years old and it has an old tv antenna wall socket and i need to replace it with a new one in order to watch television propely. I have attached photos of what the old tv socket looks like. Can anyone please help or guide me through on how to change the old socket?
    Sergeant:
  • 291 Answers
Make diagram on paper of the old socket . Carefully unscrewing old socket from wall, DO NOT CUT WIRES, copy color of wires (if any) and where and how meny wires on the paper. EXAMPLE:: you have just pulled old socket away from wall, look and see how meny wires, colors if any, and where they are in contrast to the socket.(left wire=blue, middle wire=black, left=yellow, connector that is up or down=color. MARK these wires on paper, and if possible TAPE a piece of paper with a nember[#] on the wire and place that # on the paper corresponding to the wire in socket wall.
Take the socket to electronics store.NOTE;; IF STORE does not have a exact replacement ask store for SIMULOR replacement.Show the diagram you made to help you buy the right replacement.
Good luck
Posted on May 09, 2008
What kind of antenna do I Ned and do I have to have cable for it to work
I am still using the antenna I fitted 25 years ago and it works fine for my flat tv, most new antennas will say that they are good gor hd tv, internal antennas normally have a cable built in to connect to tv but outdoor / loft ones require cable. Some homes have a wall socket for antenna feed but you need a cable to go from this to the tv.
Hope this helps
Oct 11, 2015 | Televison & Video
Need to replace radio antenna on a 99 isuzu rodeo
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
Aug 23, 2012 | 1999 Isuzu Rodeo
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
Where can I procure parts for a WF203 model TV. The part that receives the coax cable is broken and I need to replace it
Try ued.net you'll need make and model numbers, depending on how old tv is it could be either a antenna isolator or a tuner.
Aug 05, 2009 | Televison & Video
Tv will not turn on
HI, check the wall outlet to make sure that it is live.if you are using a surge protector, i would pull the unit from the protector and, try a wall outlet. sometimes the surge protector will short out and, it will seem that the TV is the issue. if the protector is fine and, the wall sockets are ok, this will confirm a more serious issue that concerns the power sector inside the unit.
You will need to replace the power supply board or, fly back assembly in this case.
Jun 21, 2009 | Zenith C27A24T 27" TV
NO POWER?
HI, try a new wall outlet in the home or business. if the wall outlets are live, try replacing the power cord. if this doesn't yield results, replace the internal power unit(inverter board)
Jun 21, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
Sansui San0218-250GB
You need 2 antenna cables. wall socket ----> DVD antenna in and DVD antenna out ----> TV
Mar 07, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Televison & Video Logo
1,442 people viewed this question
Top Televison & Video Experts
