Question about Kenmore 6000 BTU Single Room Air Conditioner
The air conditioner is not blowing any cold air
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 251 Answers
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
My air conditioner does not blow cold air what do I need to do
Check the filter to see if it is dirty. This will sometime cause warm air to blow out. Cleaning the filter has worked for me.
Here is a link for other items you can check.
Why is My Air Conditioner Not Blowing Cold Air FAQ Service Champions
Jul 20, 2016 | Heating & Cooling
Fan is blowing, but why not blowing cold?
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
It's generally either your blower motor, or blower motor ... ... And am having a problem with my ac it blows cold air normally buthot doesnt.
"Why is My Air Conditioner Not Blowing Cold Air?" [FAQ ...
www.servicechampions.net/.../why-is-my-air-conditioner-not-blowing-c...
Jan 01, 2016 | Cars & Trucks
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
The heater in my 1999 Land Rover Discovery Series 1 won't blow cold.
As per your problem mentioned.There are few solved help links to troubleshoot these problems.Go through the list and Click the link below:----
Air conditioner blows air but not cold air http://repairhelpcenter.blogspot.in/2012/07/air-conditioner-blows-air-but-not-cold.html
Car overheats and Air blows hot at idle? http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side? http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html---------- Hot air on the driver's side vents only? http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
2005 Chrysler PT Cruiser: A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold? http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold? http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Luxaire air conditioner not blowing cold air
make sure the outdoor coil is clean and is running. if it is running you may have a small refrigerant leak and be low on charge
Aug 25, 2012 | Heating & Cooling
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Air conditioner only cools sometimes
Your convergence is off. See the owners manual or call tech support to walk you through a convergence.
May 06, 2010 | Haier HPAC9M Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
144 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
