Question about Dell Dimension 2300 PC Desktop
Computer runs for 2 - 3 minutes then powers off
  • 119 Answers
You most likely have a heat related issue. Try removing the cover and checking the inside of your system. If it looks like a haunted house in there, then grab a can of compressed air and start some spring cleaning. Enough dust can accumulate in your system to preven the heat dissipation points to work correctly. Anything past this would warrant a service call from a local tech in order to replace broken fans and or heat sinks.
Posted on Aug 25, 2010
Two beep sound with no display
- First of check is your RAM inserted in ports correctly?
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Start PC in safe mode.
- Download program PCFresher.
- Run its all tools.
Your problem will be solved.
Sep 02, 2013 | Lenovo ThinkPad Edge E430 Laptop Computer
Partial loss of power
It could be a short in the magnito a dirty carb prob. Or foul plug also use fresh gas to narrow the broblem. I almost forgot check the compression.
Jun 21, 2013 | Craftsman Kohler Courage 26 hp 54" Garden...
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
I have no internet to my main computer i rerouted the cable from the router to my lap top then I have enternet but not on my main computer
First, make sure you have the internet cables on your main computer pressed in tightly (to computer and router).
Then carefully follow...
1) Unplug power cord or turn off the "cable modem" (first box that comes into your house provided by the cable company).
2) turn off your router (or unplug).
3) turn off your main computer
4) turn on (or plug in the power cord) for "cable modem" and allow it to run its startup route (1 minute minimum)
5) turn on (or plug in the power cord) for router and allow it to run its start up routine (1 minute minimum)
6) turn on your computer and let it start up and check if internet works.
good luck and rate me please.
May 04, 2011 | Computers & Internet
APC BT 1000, WHAT IS THE STANDBY TIME FPR USING 2 COMPUTER
Hi Shaick,
1 to 3 minutes is about normal runtime for running two computers with monitors plugged into each... just enough time to properly power down the computer before power goes out.
If you need UPS, Surge, or Power Related help contact:
Daniel, daniel@psihq.com, with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Mar 20, 2011 | APC Bt1000 Ups Replacement Battery...
When I turn it on it runs for about ten minutes. Off and on again it runs for maybe 5, then 3, then 2. What should I look for?
Sounds like power supply or the cable may be bad. Try another monitor on same cable or same monitor on different computer with same or different cable exchanging components until problem stops. It may be the power supply to your computer is getting bad and cannot support the power requirements you need. OR, it may be that the monitor is starting to need internal component, like relays of power supplies for itself. Try the other stuff first.
Hope this helps.
Brock
Sep 16, 2010 | LG W1934S-BN 19" Monitor
I'm running Vista, the router went bad, I installed the new one, same brand and now the computer won't connect to the internet. It sees the router ok, but there is a red X between the router and the...
If you're using the laptop wirelessly then i suggest that you remove power from the router and modem for 2 minutes. After 2 minutes plug power back in and wait another 2 minutes. Then try to reconnect to the internet.
If it still won't connect then the network drivers may have to be reinstalled. If this is the case then please post back.
Regards.
May 24, 2010 | HP Pavilion dv7-1132nr Notebook PC
Everytime I restart my computer I have to run the connection diagnostics to get access to the internet. I am running windows xp with an AT&T gateway 2 router.
Cut power to the router.
Reconnect it, and let it start-up, for 2 minutes.
Restart your computer.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG /ALL and press ENTER.
Record the information, e.g., 'IPCONFIG /ALL > temp.txt'
Type IPCONFIG /RENEW and press ENTER.
Better? Worse? Same?
Nov 01, 2009 | 2wire Computers & Internet
Crashes to windows after playing about 5 minutes
Most likely the issue you are having is your computer is under powered to run both Vista Home Premium and the game. Vista is heavy on the resources and since you are running Vista Home Premium you will need more then some running the Basic version.
So the easy fix would be to up you memory upto 2 gigs. Note best practice for Vista is to have atlest 2 gigs of ram in the system.
If you still have trouble I would test the game on another Vista computer with a 2.0 or higher CPU to see if it still has trouble. If it does not then most likely it will not work on your computer.
Also if you did an upgrade from XP to Vista you might have so Windows issue. So if the test on the other computer worked you might try a fresh install of Vista to resolve any possible Windows issues.
Hope this helps
Issken
Sep 18, 2009 | Ubi Soft Capitalism 2 for Windows
Problem on my Canon ip1880
Unplug the printer from power for a few minutes. If this doesn't reset it, then try the following:
PLUG the printer into power.
1. Press Resume button ( hold for 1 – 2 minutes )
2. Open the cover
3. Release the catridge and then put them in again
4. Close The Cover…
5. Turn Off, then Turn On
Jan 21, 2009 | Canon Office Equipment & Supplies
Dell Dimension 2300 PC Desktop Logo
21 people viewed this question
Alun Cox
