Question about Intel D101GGC Motherboard
Will this board take DDR 2 800mz memory? GC11010N
  • 565 Answers
No, you must use DDR for that motherboard. DDR AND DDR2 are not interchangeable.
Posted on Aug 24, 2010
    Sergeant:
  • 203 Answers
Ok, going by this link it doesnt take 800mz, please check the link. Scroll down till you see 'Memory'.
If this helps you out please give thumbs up thanks.
http://www.dealtime.com/xPF-Intel-Matx-Ati-Chipset
Mother board problem
Unfortunatly this board does not have DDR2 support, it supports DDR 400/333/266 memory inetrface and up to 3 Gigs. Memory banks are for 184 pin Dimms.
Apr 02, 2010 | MSI Mother Board (MSM865PEN2V) Motherboard
Physical Memory support
Hi friends,
No, you can't use the DDR2 Memory. you just need to use DDR-1 .You motherboard suppor is DDR - 400 and 333 MHz; dual channel support up to 4GB Memory.if you want to check any other information related to *********** board Click LINK
With Regards
Avnish Kumar
Jan 09, 2010 | Intel D915GAV Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
Dell Demension 4600 motherboard memory
From the Dell specifications page for Dimension 4600:
Memory
Architecture
Dual Channel DDR SDRAM
Memory connectors
Four
Memory capacities
128-, 256-, 512-MB or 1-GB
Minimum memory
128-MB DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory
4 GB
Memory type
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
Mar 09, 2009 | Dell (2336V) Motherboard
D865GSA intel mother board supports DDR1 or DDR2 ram
Straight from intels web site...
Two 184-pin DDR SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR 400, DDR 333, and DDR 266 Support for up to 2GB of system memory
Mar 09, 2009 | Intel D865GSA (BOXD865GSAL) Motherboard
Does ASRock 775i65GV supports DDR2 memory?
No only DDR upto 2GB supported by your motherboard...
Dec 08, 2008 | Asrock 775i65GV Motherboard
Memory
Yes its backwards compatible because this mother board supports DDR SDRAM type of memory, But put it mind not to mix the memory PC2100 and PC2700.
Hope that helps..........
Jul 21, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Ram support
As much as I would love to spend a couple hours making you a list of Ram that your board supports, not happening.
However you can do this your self by looking in your manual.
Download your manual here:
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=1863
Go to the top of page 15.
Your board requires a voltage of no more than 2.5v
GA-8IPE1000 Series includes 4 DIMM sockets, and each Channel has two DIMM sockets as following:
Channel A : DDR 1, DDR 2
Channel B : DDR 3, DDR 4
If you want to operate the Dual Channel Technology, please note the following explanations due to the
limitation of Intel chipset specifications.
1. Dual channel memory cannot be used if one DDR memory modules are installed.
2. If two DDR memory modules are installed (same storage capacity), one must be added to the
Channel A slot and the other in the Channel B slot in order to use dual channel memory. Dual
channel memory cannot function if both DDR memory modules are installed on the same channel.
3. If four DDR memory modules are installed, please use memory of the same storage capacity in
order to use dual channel memory and for BIOS to detect all the DDR memory modules.
We'll strongly recommend our user to slot two DDR memory modules into the DIMMs with the same color in
order for Dual Channel Technology to work.
You board supports this type of memory:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80097-16
Or
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1717669&CatId=1352
Good Luck & kind Regards.
& please vote.
Mar 16, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
Intel D101GGC Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
