Question about Dell Dimension 2400 PC Desktop
I push "on"button and nothing happens. It won't turn on. (I just moved a couple of days ago and one of the moving guys dropped my machine off the dolly!)
  • 119 Answers
Uhm, first things first. Open your case and make sure that there are no parts banging around inside. Make sure that all connectors are in place (especially from the power supply to the motherboard) and push down on the memory to make sure that it is seated correctly. If that doesn't work, then you are most likely looking at parts replacements (powersupply) and I would call on a local tech to check it out for you. Oh...and I would call the moving company and file a damage complaint....PRONTO!
Posted on Aug 25, 2010
How to fix a hand wheel that doesn't move.
if its stuck physically then don't force it , have a look with a strong light in the bobbin compartment for foreign objects , ive seen needles break off and lodge in the bobbin spool locking it tight
Mar 10, 2016 | Euro-Pro Sewing Machines
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
My actionwriter 1 won't turn on. Was informed by IBM they no longer have parts for this machine. What to do?
Check on Ebay for personal Wheelwriters or WW 1000 they will do the job and parts are available. I have a reconditioned one in stock for 225.00 with free shipping.
DickyO
Mar 15, 2013 | IBM Actionwriter 1 Typewriter Made In...
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
Apr 12, 2017 | Singer 8763 Curvy
Treadclimber tc5000 will switch on but start button won't work
Make sure the power cable is connected to a known good outlet (test outlet with a lamp or some other electronic device) and connected securely to the machine. Make sure the safety key is securely seated or belts will not move.
Jan 16, 2012 | Bowflex TC1000 Treadclimber
I have a 2006 Pride Maxima. Problem comes and goes.
Hi Alex. Does this problem happen when you first turn on the scooter, or does it happen while you are riding the scooter.
It might possibly be that the speed lever ( wig wag ), is not correctly adjusted, or is worn.
Test the lever is correctly adjusted by sitting on the machine with the key on. Slowly move the lever in the forward direction, until you hear the brake click. Take note of how far the lever moved. Now move the lever in the reverse direction until you hear the brake unit click. The distance the lever moved, should be the same in both cases.
Also while you are driving your machine try moving the ends of the lever slowly up and down. If this makes the machine change speed erratically, then you probably need a new throttle pot, or speed lever assembly.
Does your machine show any fault codes or flashing LED's.
Hope this helps. Neil.
Jul 09, 2010 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Winding the bobbin
If you can't turn the spindle easily with your fingers, it needs a drop of oil. Use only one small drop, as excess oil will cause the tire to slip. After oiling, turn the spindle until it moves fairly freely and then engage it with the motor.
Mar 16, 2009 | Brother CS-100-T Computerized Sewing...
Won't power up
Did you install correctly the cables?
Did you move any card or memory?
Check it out again!!
The fan of the motherboard is working?
Hit the reset buttom and see what happen
If doesn't work is a bad motherboard
Oct 03, 2008 | E-Machines eMachines Desktop PC
Dell Dimension 2400 PC Desktop Logo
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
