Question about HP PSC 1315 All-In-One InkJet Printer
HP 1315 all in one printer/ Ink cartridge problem
When I insert a new black ink cartridge I keep getting an error message, to check the cartridge. The color cartrdge is fine it is just the black one that is giving me a problem.
  • Anonymous Sep 09, 2008
    Printer has been out of use for 6 months and now will not print. Any suggestions for getting the ink up and running?
  • 975 Answers
Clean the printer contacts with a Q tip and video head cleaning solution , re install the cartridge try again , hope this helps
Posted on May 05, 2008
Why do I continue to get the E error message and blinking light on cartridges
The 'Ink Alert' or 'Low on Ink' message displays on the computer or on the product control panel.If the cartridge has been refilled or re manufactured, 'Low on Ink' or 'Ink Alert' or error messages appears on display panel.Replace with the new genuine cartridge which is showing error on display..
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
I put a refilled black ink in my HP PSXçC
the problem with the refilled ink is that the ink is NO WHERE near as good as the original HP ink and the ink cartridge is now damaged - just replace the cartridge with a new HP cartridge and you should be OK!
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
I continualy get error msg to check printer cartridge, when new ones are installed same msg repeated.
I just replaced my black ink cartridge on the same printer and I'm encountering the same problem: a message that states "the black cartridge is not compatible with this printer". Well, that's not true. It is compatible. As a matter of fact, I got my printer (with new cartridge installed) to print a page once. But, now its giving me problems again and I can't get it to work. Help!
Oct 28, 2009 | HP PSC 1315 All-In-One InkJet Printer
Error message saying incorrect print cartridge.
Check the Electrical contacts on the cartridge itself, they all need to be clean and nice and shiny to work properly. Make sure you haven't overfilled the cartridge too, this can sometimes cause problems. To be honest, the HP cartridges do 'wear out' after a few refills. when they go electrically dead, there is nothing you can do about it apart from buy a new one!
Oct 21, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP 1315 printing real slow
If there are a compatiable black cartridge
replace this cartridge with your old empty cartridge and print a test page (don't mind about printing of black )
If speed is correct,
then replace the black cartridge with another new cartridge.
(some time compatiable black cartridge not work properly to flow ink)
Jun 04, 2009 | HP PSC 1315 All-In-One InkJet Printer
Needed new ink
You could try to remove both ink cartridges.
Closed cover
Reinstall both cartridges again
If still do not clear
Turn off printer
Wait awhile
Turn printer back on
Mar 15, 2009 | HP PSC 1315 All-In-One InkJet Printer
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink Cartridge
There can be problems with the cartridge itself...check the cartridge number with the original cartridge (ex :- 27)...
You can try
# wipe the cartridge circuit board with a dry cloth (can have dirt)
<PLEASE RATE ME AS FIXYA>for my help......................
Jul 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Print Cartridge Error
Hello -
Did you perhaps not mean to post under the 1315? I am not sure if you have this printer or another model. The 1315 normally takes a different number ink cartridge.
Meanwhile - gotta tell you that the 1315 is the buggiest printer I ever had. If you purchased it recently and can find your receipt, I'd take it back! Since they've pretty much done away with the 1315, if it was a recent purchase, it was likely a clearance item from some place.
Try taking all the ink cartridges out, uninstall the printer entirely, and reinstall it (the entire printer, not just the cartridges). Blow your printer out with canned air as well - dust, pet hair, people hair, fuzz and general paper fibers can build up more than we think, and cause error messages and other printing problems.
That should help, if it was the 1315 model.
That being said, note that if it still doesn't work, and you have the 1315, save yourself a lot of grief and toss it in the trash and buy another cheap printer! 1315 is Bug City!
Jun 07, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
371 people viewed this question
Seeker5211
Seeker5211
