Question about GE (PSS26MSRSS) Side by Side Refrigerator
When i use my water on the door water seeps from the back right side underneath frig
You probably have a guick-connect fitting where your water tube goes into your door that is leaking. it looks like it is 1/4 inch but it is not! If that is the problem, you will have get one from a G.E. service center to replace it with. It wont cost much.
Posted on Aug 24, 2010
Kitchenaid superba frig.past 2 days high pitched over temp light alarm goes off every few hrs in between reset we cleaned coils temp in freezer seems fine but frig is not please help
May be frozen up or plugged up. Remove all food. Unplug it and open the doors. Leave for 24 hrs. Clean up any water. Clean out the tray underneath. Usually access from the front if you can pop off the trim panel under the doors. Pull it out. Remove the back. Inspect for large amount of debris. Check any cooling fins etc. use a vacuum with a hose to clean it all out. Plug it back in and try it.
Sep 15, 2015 | KitchenAid Superba KSRG25FK Side by Side...
I have an Amana side by side refrigerator model SXD225SW and the other day water began leaking from underneath the refrigerator. As the couple of days have worn on, it seems as though the amount of water...
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout......
Aug 15, 2010 | Amana SXD524VW Side by Side Refrigerator
Where do I hook up the water line, on the right bottom of freezer
there should be a water valve with a 1/4 compression male connection on it in plain sight. If it is not there, I could only venture a guess that someone has removed it. Was this a new frig? On the picture I see it has a dispenser in the door so I know it should have come with a valve. I doubt you are missing this though. ALL of the frigs I have seen, it is at the very bottom right if you are looking at the back of the frig.
May 27, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water filter for ed0gtqxkq00
I looked up your frig and I did not see a filter. If you want to use one, you can install what is called an inline filter. This is simply a filter you install behind the frig attached to the water line going to the frig.
All you have to is unhook the water line from the frig, attach it to your newly bought inline filter, and install another water line on the other side of the filter and hook that back up to the frig!
So now you have a filter and two water lines :) Just make sure to point the filter the right way, the usually have an arrow on them. The water is supposed to flow through them in a certain direction.
May 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
GE Profile Side By Side leaking water on to floor
there must be a hole in the lower back of the freezer compartment that carries the water to the drip pan when the fridge goes through the defrost cycle. Water on the floor means that hole is plugged and the water seeps through the doors. See the owner's manual - it will describe this issue. The fix is to have the blockage removed by squirting a solution of hot water and baking sode with a turkey baster or a similar injector.
Mar 13, 2009 | GE Profile PSI23NCR Side by Side...
Water seeping around fitting on back where water line fastens tp
Where does the water seep from?
The compression fitting you speak of is for the ice maker and through door water (if you have it.).
If water is on the floor, then chances are the drain pan underneath the unit has a hole in it, or for some reason, the water is not getting to the pan.
If water accumulates inside the freezer, check that the tube leading to the pan on the bottom of the refer is not clogged in some way.
If the water is in the refrigerator side, there may be a hole in the tank for the through the door water dispenser. It would leak everytime the icemaker dropped ice and refilled.
Jan 19, 2009 | Amana ARS2464B Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
24 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
