Question about Philips 2.1 Multimedia Speaker System - Black Speaker
I own the philips multimedia 2.1 mms171. I am experiancing a fuzzy noise from my two speakers. no problems with the sub woofer
5 Suggested Answers
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
simplemitch
  • 752 Answers
SOURCE: bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Posted on Aug 05, 2008
MNfisherman
  • 11896 Answers
SOURCE: Need to download new sound driver for computer speakers
Philips.Drivers-Updated.net
Driver-Pro.com/Audio
Audio.WindowDriver.com
Philips.Drivers-Fix.net
Posted on Sep 28, 2009
SOURCE: i buy the Philips Home Theater with star cj aliva
Dear Customer,
Can you please share your order number and we'll look into
this?
Thanks
STAR CJ Team
Posted on Feb 26, 2011
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer and computer to only one power point. Connect all your equipment to one power point using a power board.
Apr 12, 2012 | MidiLand MLI-699 Computer Speakers
I have a subwoofer can i hook up to computer speakers
Yes you can. cut the left speaker lead and splice a wire from it to your sub woofer. If its a powered woofer you may have too much gain going in, You don't say what kind of sub it is or weather or not its a "powered" unit. If its a powered woofer (built in amp) you should take the output directly from the computer output (buy a 1/8 in male to 2 1/8 in female connector, send one output to your original speakers and the left side of the second output to the sub woofer. you can usually adjust the level of the sub (if powered) with a control on the unit. if you need more help, contact me but please tell me more about what you have.
Mar 18, 2011 | Altec Lansing Multimedia Computer Speakers
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Sep 28, 2009 | Philips 2.1 Multimedia Speaker System -...
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Bose acousticmass 15 sub-woofer making a noise
Jun 24, 2008 | Bose Acoustimass 15 System
Fuzzy sounds quality from receiver
your surrounds are probably set too high and the the center set too low
Mar 06, 2008 | Yamaha RX-V661 Receiver
Sub issues
Would suggest that the power amp in side the speakers havs failed. Try to plug the speakers into a ipod then you can prove if tis the speakers or the Pc.
Jul 25, 2007 | Philips MMS171 Computer Speakers
Philips 2.1 Multimedia Speaker System - Black Speaker Logo
75 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
