Question about Frigidaire Refrigerators
I have a Frigidaire Model # PHT189WHKM2 and I just bought a part # 1155209 Valve-Water,triple solenoi and I lost my sheet that I had to hook up the way the hose go into the Valve because the icemaker is not receiving water but before the unit went bad it was working, so I brought the part and need help to install the hoses the right way. I would like to know to you have a system on how to put back the hoses on the valve.
  • superjo140 Aug 25, 2010
    I need some type of diagram on how the hoses get hook up to the triple water valve solenoi that's what I meant. The valve was removed and when purchase I need to locate what hose goes where on the valve.
    Thank you
  • 3,083 Answers
Couldn't find any diagrams for this model on the net. Not sure if this will help, but here is a site that shows the general diagrams of various style refrigerators, and may be of help to you:
http://www.repairclinic.com/Refrigerator-Troubleshooting
You could also take a couple pics of the valve, and just take them to a Appliance Repair shop...they'll often tell you what you need, and how to hook it up.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Aug 25, 2010
  • 857 Answers
Please follow the instructions mentioned below:
1• Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
•2 Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
•3 Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
•4 Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
•5 Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
I changed the triple solenoid valve on my Frigidaire mod. FRS6LF7FS3 because frig not making ice. Still no ice. If I manually put water in the ice maker it freezes and dumps
Bummer deal. I would say trash is blocking the flow of water at some connection - maybe as it enters the cube-making device.
Feb 27, 2015 | Frigidaire Refrigerators
We bought this used and brought it home and we know it worked we saw it working now it is hooked up at our home and it will not fill with water.
Hello friend, thank you for your post!
I understand that you have recently purchased a Frigidaire washer and it is not filling up with water. I would check to make sure that the valves are fully opened. If the valves are opened it could be a possible problem with the water inlet valve, control panel, or pressure switch. I would advise seeking assistance from a professional technician for proper diagnosis on your washer. -Matt
Oct 20, 2014 | Frigidaire Washing Machines
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Ice maker not working
Try filling with tap water and allow water to freeze. Once the water freezes and ice dumps into ice bin and water does not refill this will point to the dual water control valve. On the Model FRS6R5ESB0 that part is a Triple Water Control Click Here=> 241734301 Water Inlet Valve I will be here should you have questions but for now please try the tap water fill test and let me know how that turns out, Thanks, Sea Breeze
Mar 20, 2012 | Frigidaire FRS6R5ESB
Not making ice
There are a few simple test you can do that will answer what the problem is. First look inside of your ice maker and see if there are cubes remaining and if yes just check the switch to be in the on position. Look and see that the ice bin full feeler arm works freely. If the ice make still has cubes the problem is most likely the ice maker. If the ice slots are empty the most likely reason is your triple water control valve=> 241734301-2 Triple Water Control Valve You can test that by filling the ice maker with tap water and if after the water freezes the ice maker drops the ice into ice bin and then does not refill with water replace the water valve. If have any question please feel free to ask, Thanks Sea Breeze
Click Here=> FRS3R5EMB_Ice_Maker_Components
Click Here=> FRS3R5EMB_User_Manual.
Ice Maker=> 5304458371 Ice Maker
May 07, 2011 | Frigidaire FRS3R5EMB Side by Side...
Model frs23lh5ds9 repairing water valve when solenoid energizes to fill ice maker water is also dispensed at door
Your model has a triple water control valve. That is part number 241734301
That is the possible reason something has cause them to send water to both places. Does your model also have a water filter below or inside the refrigerator? I will need to find a set of better photos/wiring diagrams to understand why this is happening. I will try my best but I will need to go to Frigidaire to look over the refrigerator you have, I just am trying to picture the water lines and I admit this is one strange case.Let me know, Sea Breeze
Nov 20, 2009 | Frigidaire Refrigerators
Not getting water to my icemaker.. water is coming out of the water side(drinking)water is coming into refrigerator from mainwater supply. replaced water triple cylinode valve already, but not getting...
frigidaire has put a diode in the harness @ the water valve sounds like diode is bad . hard to find @supply houses may have to order complete wire harness haundi24
Oct 12, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice Maker gets flooded with water when using the water dispenser
There is a diode in the wire harness near the valve. It has failed allowing power to go to both valves at once.
Unplug the wire from the valve to the icemaker and unhook the icemaker. This should stop it until you can get the part.
jim
Jul 27, 2009 | Frigidaire FRS26R4A Side by Side...
Replacing Secondary Water Valve? How does it hook back up?
white connector on the valve connects to the icemaker fill line
gree connector on valve to water in the door
blue connector to the filter or house connection
May 17, 2008 | Refrigerators
Refrigerators Logo
60 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
