Question about Yamaha DSP-A1000 5-Channel Amplifier
Where can I buy a replacement selector switch for the Yamaha RX-750 Receiver?
    Genius:
  • 1,175 Answers
Hi,,,
Try encompass parts on-line 1st If not there , try yamaha direct
Yamaha Parts Department at (714) 522-9011
PLease rate my help.
Thanks
Posted on Aug 25, 2010
I have a AV receiver RX-V440 Yamaha and........
The title of your question reads "I have a AV receiver RX-V440 Yamaha..." yet you say you are using the manual of an RX 1020L. I will try to provide a suitable answer for both receivers.
First, a "MON" connections on an amplifier or switching unit is normally used as a line level OUTPUT from the amplifier or switch. Line level outputs are sent to RCA connectors on other TVs or amplifiers (or switches).
"MON" should not be wired directly to the OUTPUT of anything trying to "playback". It should be connected only to things that can record or allow you to see or hear what the amplifier is outputing.
Now to answer your question:
The RX-V440 is a 6.1 channel Home Theater Receiver. If you stand behind the receiver and look at the left hand side, you will see 12 RCA connectors (2 L/R by 6 high). The top 2 connectors are labeled "CD". The next set of 2 connectors are labeled "IN/(PLAY)". The third set down from the top are labeled "OUT/(REC)".
You can connect the reel-to-reel output to either CD or IN. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select CD or IN on the RX-V440.
The RX 1020L is also a multi-channel receiver. If you stand behind the receiver and look at the left hand side near the center (top to bottom) of the receiver, you will see RCA connectors labeled "AUDIO 1" through "AUDIO 4".
You can connect the reel-to-reel output to either of these. The primary purpose for "AUDIO 3" and "AUDIO 4" is to allow you to hear component video input AV1 and AV2. If the reel-to-reel has a selector switch, set it to "Output" and not "Monitor". If the reel-to-reel has volume controls, set them such that music causes can be heard when you select one of the "AUDIO 1", "AUDIO 2" or whatever on the RX 1020L receiver.
Nov 21, 2017 | Audio Players & Recorders
I have a Yamaha RX-385 receiver. I want to increase the number of speakers I can use from the receiver. I am considering buying a speaker selector that says it can connect 4 sets of speakers I can run to...
This speaker selector is standard accessory equipment for home audio equipment -- just follow the instructions with the unit.
The speaker selector unit has circuitry which prevents the amp from being overloaded by connecting too many speakers in parallel to the receiver. The receiver will have to be run at a higher volume level to drive all the additional speakers at the same volume as two sets of speakers, but this will not damage the amp in so doing.
Charlie
Jul 17, 2011 | Yamaha Audio Players & Recorders
My 7 year old Yamaha RX-V870 receiver won't stay on. I press the power switch, the display lights up and after about three or four seconds, it turns off. Every time that I press the power switch the...
Get your service manual here:
Yamaha RX V870 Manuals
FIRST be SURE your speakers are connected! A loose wire can cause shutdowns as your Supply tries to protect your output transistors!
Your Yamaha also HAS a onboard DIAGNOSTIC feature but it won't do you much good now because your supply is going into emergency shutdown so quickly... see page 15.
Suspect a problem in your Power Supply.
*** WITH THE POWER DISCONNECTED ***
Inspect the electrolytic caps for leakage AND be sure the tops are flat and not bubbled.
Find your power supply on pages 46/47/48. It is VERY extensive and has MANY possible suspects. NOT for the weak of heart!
Anthony
Feb 04, 2018 | Yamaha RX-V870 Receiver
I dont know how to connect the wii to my rx-465 receiver.
The Wii AV cable should have a red/white pair of Audio Output jacks on it.
Check out pg. 8 of the Wii manual: http://www.nintendo.com/consumer/downloads/WiiOpMn_setup.pdf
Connect the red/white RCA plugs from the AV cable to a line level audio input on your receiver. If you use AUX IN, then select AUX IN on the INPUT selector switch. You should then hear the sound from the Wii through your receiver/home theater system.
Mar 11, 2010 | Yamaha RX-V463 Receiver
My reciever has no sound. everything else still works but it just won't put out any sound at all. yamaha RX-V863 7.1 channel. less than 6 months old.
Check your "A/B" speaker selector switch on the front panel of the receiver, if they are on, you will see "A" "B" or"AB" on the front display. If they are on, You need to have the receiver serviced. Just a note, Yamaha's rarely have an output problem! Hope this helps
Jan 09, 2010 | Yamaha RX-V863 Receiver
I have a Yamaha Natural Sound Stereo Receiver RX-750 (purchased maybe around 1992-1993?). The input selector switch doesn't seem to be working properly. No matter which input I select, the sound is fuzzy...
Hi cfipp
You could fix this problem with a quick squirt of CRC 2-26 into the function selector switch connected to the knob you are wriggling. This will sort out the problem. If you need further advice, feel free to ask me. I will help you.
regards robotek
Mar 07, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha DSP-A1000 5-Channel Amplifier Logo
267 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
