Question about Ruud Matching Split Air Conditioner
Ruud achiever 10 seer air conditioner has weak airflow, I changed the filter and one of the coils on inside unit is frozen
  • 674 Answers
Turn the unit off and give it time to thaw. A hair dryer can speed this process along. How did the filter look? When the coil has thawed check to see if it is dirty. Also make sure your indoor fan is running and all the covers are on the air handler. A weak capacitor will make the fan run slow. Let me know what you find.
Posted on Aug 25, 2010
Ruud ubha-21j00nuaa
Can you see the condition of the coil itself? If it is blocked this could be a cause for the frozen coils. Also, check the condition of the blades on the indoor fan. Dirt and dust accumulation on the blades reduces airflow.
Jul 14, 2014 | Ruud Handler Air Conditioner
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
I have ruud achiever 10 seer air condition to my house and some reason all of sudden is not working at all. i found out that the parts inside it with the coil is not automatic turn on, i have to press it...
I think you are describing the contactor if so it could be bad or you do not have 24 volts going to it from the thermostat thats what lets it come on.
Aug 30, 2010 | Ruud UBHC Air Conditioner
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Matching Split Air Conditioner Logo
159 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
