Question about Hayward SAND FILTER, PRO SERIES
Our hayward sand filter just started making a loud high pitch humming noise. Last week we had to replace the variflo gasket and now this. Motor feels hot to the touch and pressure of filtration is at 10. Help.
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Since you mention the motor being hot I am guessing you meant to type "your pump is mkaing a high pitched...". If that is the case, your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Aug 25, 2010
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
Vari flo handle not working properly
Which model year VariFlo?
  • Some model years do not take a spider gasket as there is spider gasket type bead molded into the diverter/key hub assembly.
  • Spider Gasket, raised bump should face up & gasket should be glued down down to prevent it moving.
  • Spring & nylon washers could also be bad.
Sep 11, 2012 | Hayward SAND FILTER, PRO SERIES
My Hayward Tristar 1.50 HP pump is 3 years old, and recently developed a high-pitched humming noise that is causing a noise disturbance. The performance seems to be operating okay, but it never used to...
sounds like the bearings are going out on the motor. The noise will increase as they wear out more until it locks up and throws the breaker. You can have the motor rebuilt or just replace the motor. Consult a pool professional to help out with this.
Nov 22, 2010 | Hayward TRISTAR PUMP 1.0 HP, 115/230V
I turned the pump on and it is making a humming noise but is not working
the most common problem for the symptoms you describe is a bad start capacitor. There should be a hump on the motor. Remove the two screws that attach it and replace the capacitor inside with an exact match. If it has a start/run capacitor, it may located under the end cover of the motor.
Apr 07, 2010 | Hayward SAND FILTER, PRO SERIES
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
We have a hayward pump and the motor keeps stopping and tripping the circuit breaker. What could it be?
The motor might be too powerful for the line it's on, (usually a pump should be on a somewhat dedicated line) no Ac's running on same breaker.
An extension cord longer then 6ft is also a suspect in not allowing the pump the draw enough power.
The pump may not be drawing enough water, overheating and tripping the breaker, or the motor might have rust on the inside causing the armature not to spin freely, and shut off. (usually motor will make a high pitch noise) while running)
Jun 29, 2009 | Hayward Pro Series 18" Above Ground Pool...
The top of my filter is faded need to know where the spot for filter ,backwash etc. is on a s190t dream filter
Contact us through the contact button at www.arrowmotor.net. I can reply with a scanned copy of the valve literature that includes a layout of the Hayward variflo settings.
Jun 11, 2009 | Hayward SAND FILTER, PRO SERIES
Motor humming but not engaging
The pump needs to be primed by adding water to the basket.If it still doesnt start it might need the a rebuild which usually involves replacing the bearings(cost about $150.00 NJ area).
Apr 22, 2009 | Hayward S220t Top Mount Pro Series Sand...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Hayward SAND FILTER, PRO SERIES Logo
151 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
