Question about Honda Maxus Prosumer MX5223 Pressure Washer
My pressure washer inlet tube does not syphon chemicals. The hose is fine and the strainer is new. Do I have to do anything to the pump body to make it work? It is a 2750psi Honda
    Problem Solver:
  • 18 Answers
You have downstream injection and this means only with low pressure will **** chemical you need a soap nozzle or check your injector make sure is in the right direccion
Posted on Aug 25, 2010
The pressure washer will not syphon chemical, the hose and filter are clear and it still doesn't syphon. there is a fitting at the bottem of the line that constantly has water coming out that may...
Use the blacks nozzle to get soap.
but if water is coming out from the soap hose then the injector is bad.
i will need your model #
Sep 29, 2014 | Garden
Servis m9503 washer dryer continuously fills with water,pressure switch and tube are ok,pressure chamber cleaned out and drain hose right height
if u checked the pressure switch aand its ok then look at your water inlet valve?
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed
By the way my advice is free cuz God is good!
Nov 20, 2013 | Equator EZ 3612 CEE Front Load...
Broken plastic water inlet connection.
I have the same problem. The design is bad with the weight of the hose and the lelength of the plastic inlet tube from the body creates a sheer force that causes it to break. I cannot find anything but a plastic inlet part. If someone would create a metal inlet connector they could make a lot of money. You need a lot of hose slack when moving your power washer or it will break off the inlet and the parts are abotu $20. Very poor design!!
May 08, 2012 | Honda Black Max 2600 PSI Pressure Washer
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
My Karcher 2400 Pressure Washer will not syphon cleaning fluid. I have a reconditioned machine and the syphon for cleaning fluid has not worked for a while.Everything looks clean but still does not work'...
The black tip nozzle puts the right amount of pressure on the line to draw up the cleaning solution.
If your power washer is like mine, the cleaning fluid adapter is a 'T shaped' brass valve that fits in-line along the hose line.
There is a brass stem sticking out.
The stem has a tiny ball valve on the end.
A plastic hose fits onto the stem, and the plastic hose goes into bucket of cleaner.
As water travels through power washer hose, it creates suction that draws cleaning solution through the tiny ball valve.
The brass ball valve gets clogged or wears out ... we used to replace the stem every so often.
Sherwin Williams used to carry a replacement stem ... but they may not sell little parts any more.
It's been 14 years since I used the suction device.
I got fed up with the thing not working.
We changed over to a pump-up hand-held sprayer for applying cleaning chemical.
The pump-up puts more chemical on the spots where you need it.
So one guy puts chemical on, and second guy comes behind with power washer ... no more replacement parts, and one tip stays in the gun so we never lose a tip.
A pump-up sprayer is half the cost of replacing the T-shaped valve.
Duh-simple is the business model.
Nov 17, 2010 | Karcher Garden
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 | Garden
I have a unionpower up 150 premium pressure washer theirs a small hose that comes out at the back of the engine with a small filter at the end of the hose pipe I dont no what its for
If the hose actually comes out of the pump (look carefully) it sounds like the chemical pick up line. It would most likely be clear plastic tubing with a plastic filter at the end. You drop this into your chemical (soap, etc) container and under low pressure it will siphon the chemical and apply it through the wand.
Jul 29, 2010 | Garden
Need a picture of oil pump for 1993 cherokee straight 6
Jeep Wagoneer/Commando/Cherokee 1984-1998 Oil Pump - Removal & Installation
2.5L and 4.0L Engines
(see Figure 1)
  1. Disconnect the negative battery cable. Raise and safely support the vehicle.
  2. Drain the engine oil and remove the oil pan.
  3. Unbolt and remove the pump assembly from the block. Discard the gasket.
WARNING If the oil pump is not to be serviced, do not disturb the position of the oil inlet tube and strainer assembly in the pump body. If the tube is moved within the pump body, a replacement tube and strainer assembly must be installed to assure an airtight seal.
To install:
  1. If a new pump is being installed, prime the pump by submerging the strainer in clean engine oil and turning the pump gears until oil emerges from the pump feed hole.
Fig. 1: Oil pump inlet tube installation
  1. Using a new gasket, install the pump on the cylinder block. Tighten the short bolt to 10 ft. lbs. (14 Nm) and the long bolt to 17 ft. lbs. (23 Nm).
  2. Install the oil pan and lower the vehicle.
  3. Fill the engine with the proper type and quantity of oil.
  4. Connect the negative battery cable. Start the engine and check for proper oil pressure.
Hope this help (remember comment and rated this).
Apr 20, 2010 | 1993 Jeep Cherokee Country
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Honda Maxus Prosumer MX5223 Pressure Washer Logo
254 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
