Question about Turboair Refrigerators
Inside fans blowing smoke (burning plastic smell)
  • 2,973 Answers
Smoke and smell of plastic indicates that there is a short circuit inside. It is the protective covering on the electric wires. Unplug the refrigerator from the wall and call the repair person.
Posted on Aug 24, 2010
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Small puff of smoke coming through the top right of the laptop
The fan usually wont fail in that manner, If it still works normally, you can go to www.almico.com and download a program called speed fan. It is free and it will tell you the temp of everything in that computer.
Feb 09, 2014 | Advent 6552 Laptop
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
Smoke smells when ac on nissan sentra
The speed control of your fan has resisters that are in the venting system to blow air on them to keep them cool. If they overheat and or burn you will lose your low and medium speeds of the fan. If you run the fan at full see if the smell goes away. Your engine could be burning oil on the outside of the engine block, make sure that the weatherstrip where your hood meets the fresh air intake grill is sealing tight.
Nov 26, 2013 | 2001 Nissan Sentra
Burning candle smell
this could be your heater core leaking antifreeze and the smoke may be steam
Jan 04, 2013 | 2000 Nissan Sentra
My problem is simple to describe: The computer starts and runs fine,except for the smell...and the heat. The smell resembles burning plastic,and the heat output is noticeably higher. There's no smoke...
It more than likey seems to be your fan if the heat from your tower is noticeably higher and the smell.
If computer still under gaurantee you will be able to get it repaired for free from the manufacturers.
If not, take the tower cover off, and get a hoover and **** all dust particles from the system.
You may also need to invest into another fan, this should stop the smell and also the overheating
Hope this helps and please rate thanks.
Mar 26, 2011 | HP Pavilion s7320n (EP140AA) PC Desktop
Engine coolant mixing with oil in reserve tank. blowing white smoke out exhaust
The intake is leaking,if it is a plastic one,replace the whole intake,if it is metal,replace the gasket.
Jan 24, 2010 | 1999 Ford Windstar
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Jan 04, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Refrigerators Logo
109 people viewed this question
Top Turboair Refrigerators Experts
David Jewell
jasbo
jasbo
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
