Question about Intermatic Inc. ST01C Digital In-Wall Timer
As to 0912773: the manual leaves out many things that one has to know in order to set and use the switch. As it is, the switch doesn't work at all, except as an ordinary manual on/off switch. $25 and 2-hours of my time to get an ordinary switch that doesn't even match my paint! I'll be on the lookout for this company and never buy another product of theirs. (Right; this isn't a question: I give up.)
Tiny print on the instructions is enough to aggravate ya fierce.
You are replacing switch that has 2 wires with a timer that has 4 wires.
1) 5 minutes to Test wires: If your switch has 3 wires, then you have wrong timer. You need Intermatic ST01C or EJ500C. If your switch has 2 wires, then continue: Disconnect both wires from existing switch. Pull them out where you can test with ordinary tester. Power is on. Test each wire from switch to bare copper wire. When test light comes on, that is the hot wire and it is probably Black.
2) 3 minutes to connect wires:
Timer black wire goes to hot wire which is probably black
Timer red (or blue) wire goes to other wire that was connected to switch
Timer white wire connects with other white wires that are held together with a wire nut and pushed to back of box. [If box does not contain other wires, connect Timer white wire to bare ground wire.]
Timer green wire connects to bare ground wire
3) 5 more hours to program timer
Tiny print shows 5 steps for programming timer. Write the steps out so you can see them clearly. Drink a glass of water. And pull a chair in front of timer to set 7 on and 7 off programs. It will work fine.
Posted on Sep 21, 2010
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
D945ghz
Intel D945GZ motherboard? Got it. Now what the world are you talking about? A Chassis Intrusion Switch? What desktop computer is it in? Computer manufacturer name, and Model Number. Post back in a Comment.
Wait a minute. Won't boot, or the Power Supply doesn't start up?
Power Supply doesn't start up;
1) You have a bad ATX power on switch
2) You didn't connect the ATX power on switch to the correct pins, on the Front Panel header.
3) You have a bad Power Supply
http://www.directron.com/atxswitch.html
Computer doesn't boot up;
1) You didn't follow Anti-Static Precautions
2) You didn't apply Thermal Paste to the top of the Processor, before you put the Heatsink on.
3) You didn't connect the 4-pin ATX +12 Volt power cable.
Power for the Processor. (No processor, no computer)
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
4) You didn't use the Installation Disk (CD) that came with the motherboard. (Has the DRIVERS)
5) Is this a replacement motherboard for a bad one?
SAME motherboard, or a different one?
Why?
Because when Windows is installed on a computer, (Harddrive, actually), it assigns hash values to certain major hardware components.
Components such as;
1) Processor
2) Motherboard chipset
3) BIOS program, version, and date
4) Harddrive
5) Graphics chipset. (Whether Integrated Graphics, or a graphics card)
Change any two of these components, and Windows will think it is being stolen.
Microsoft User's License states, "ONE Genuine copy of Windows per ONE computer "
[ Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
If you are lucky, the Windows activation screen may come up. Windows will want to be activated again. (Activated, not Registered)
Doesn't happen all the time, though.
Using a brand new genuine copy of Windows? Make sure you go into BIOS Setup, and in Boot Order, set the first boot device to CDROM.
The LED light on the motherboard indicates it HAS power.
Motherboard Manual for the Intel D945GCZ mobo. (MOtherBOard),
(GHz stands for GigaHertz.
Giga = approximately 1 Billion.
Hertz stands for Cycles per Second.
1GHz = approximately 1 Billion Cycles per Second.
It refers to Frequency Rate. For laymen frequency rate = 'Speed')
Plus, it isn't new. It is NOS. New Old Stock.
Means it could be a bad motherboard, even if it has never been used.
{Computer technology follows Moore's Law,
http://en.wikipedia.org/wiki/Moore%27s_law
What is new technology today may be old tomorrow }
http://www.intel.com/support/motherboards/desktop/d945gcz/sb/CS-020793.htm
Blue -> English Product Guide [PDF]
Let me know if you think there is a Chassis Intrusion Switch.
It will operate one of two ways;
1) When the cover is removed, the switch is open. No connection of the two wires is present. Remove the switch, put a piece of heat shrink tubing over one wire, and slide it back out of the way.
Twist the two wires together with an Electrician's knot, solder them, slide the heat shrink tubing over the connection, use heat to shrink the heat shrink tubing.
2) When the cover is removed, the switch is closed. The wires are grounded out. Remove the switch. Cut the exposed bare wire off, leaving just the insulation. Put a wire nut on it. Do the same for the other wire.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 24, 2012 | Intel Computers & Internet
Sharp Carousel Model R-209KK-W is flashing all 8's and keypad not working
The first thing to try is to do a hard reset.
Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still doesn't work, it may need repair, which can be done for $39.95 in most cases.
Jun 10, 2012 | Microwave Ovens
My HP Compaq nc8000 is stuck on
Try these things. Press and hold the power button until it shuts down. If that doesn't work, unplug it and leave it on until the battery dies, then find someone who can replace your power switch.
Mar 15, 2012 | HP Computers & Internet
I need to know which relay controls the blower motor.
If the blower does not work at all the first thing I would do is tap the blower motor with the handle end of a large screwdriver with the key on and the blower speed set to high. If the blower starts to work than replace it. If it still doesn't work wiggle the connector at the blower motor. If it starts to work replace it.
Other wise read through this how to tip
http://www1.fixya.com/cars/r6571076-blower_motor_not_work
If that doesn't help than I will need to know if you have manual or automatic HVAC. with automatic you will set a temp and it will automatically maintain that temp.
Once I know that I will be able to help you identify the blower motor relay.
If you have any questions let me know!
Oct 14, 2011 | 1995 Buick Park Avenue
When power went off and then came back on, screen on micro wave continually shows demo and I cannot set time
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still won't work, then you may have a bad membrane keypad / DP circuit.
If your model is NN-P295SF, the service is here.
Parts can be ordered from Encompass here.
Aug 19, 2011 | Panasonic NN-P295SF Microwave Oven
Panasonic p295sf no read out on the screen and won't shut off
Otherwise, the service manual is here.
You can order Panasonic parts from
Encompass here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases with a one-year guarantee.
Jul 30, 2011 | Panasonic NN-P295SF Microwave Oven
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Photography
Dyrer on comes on when button is press, once you let go it turns off. we have to keep the button pressed in at all times in order for it to work.any ideas???
place a jumper wire , between the 2 wires that attach to the start button, if this fixes the problem replace the switch , leaving it on all the time will burn it out since its a momentary switch , if that doesn't fix the problem, then check the door safety switches, and the control thermostats
Jul 09, 2011 | Maytag MED5600TQ Electric Dryer
The manual in Utilitech self adjusting wall time box is not the manual to switch # 0912773, as stated; it is the manual to switch #141224. The instructions programming the timer don?t match the buttons on...
You might find the correct information at this URL:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
Do a copy and paste in your browser and review for the information you are looking for.
Paul
Sep 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
78 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
