Question about GE DBL333EA Electric Dryer
TI am trying to replace the belt on my GE DDE7200SBLWW but the belt is loose. Do you have a diagram or instructions on how to thread the belt to get the proper tension?
  • teramarshall Aug 24, 2010
    the diagram that you sent is for a different dryer. My dryer does not have a spring. My tension wheel is on the end of a long arm that can be moved backwards and forwards. When I thread the belt per the illistration it is too loose. There isn't a manual available inside my machine.
    I believe I have the belt in the correct configuration but the idler pulley is not putting tension on the belt. The belt is really loose and the dryer will not turn on.
    President:
  • 1,554 Answers
The idler pulley (tension wheel) is installed on the short end of the idler spring and the long end is inserted into the bracket at the base of the dryer. Insert the idler spring into the slot on the bracket in the direction of the motor. In this manner, the idler pulley is pushed against the belt as shown in the diagram below.
Belt diagram facing the rear of the dryer.
Posted on Aug 25, 2010
  • Jahn27
    Jahn27 Aug 25, 2010
    Make sure to install the idler spring properly. Replace the idler spring if it is bended/deformed or not pushing enough against the belt for proper belt tension.
    Please make sure to accept the solution should you find it helpful and informative. Failure to do so will automatically give credit to the first solution no matter how non-informative or not helpful it is. Accepting a solution does not
    stop you from communicating
    with an expert. You may continue communicating with the expert as
    long as you need assistance regarding the issue stated herein.
  • GE Master
  • 12,061 Answers
Http://www.dryerpartsonline.com/WE12X82-GE-Dryer-Belt_p_224.html
Hi, well this is a pretty simple job.
Take a look at this website above, there is a picture, on how to Thread it. (A small pic, but it's easy to see how the belt threads)
Also, often there is a manual of sorts, inside the dryer under the inspection hatch.
Posted on Aug 24, 2010
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Belt replaced around drum, too loose! Parts store insists it is the correct size for GE dryer. Model # DBXR453GT3WW (1996) Can't figure out what is wrong?
The part# i have for that model number for the belt is WE12M29 the previous part number for that was WE12M22 is either of those the part number for the belt ?? if yes it should be the correct one
one more thing that may help ya is view the diagram here of how it fits onto the idler pulley/motor pulley http://www.repairclinic.com/Dryer-Belt-Diagrams for your dryer it will be DIAGRAM L
GENE
Aug 29, 2011 | GE Dryers
How to get to heating elements on ge dryer model dde7200sblww
Most of the newer models you work from the front only. The heating coils are on the rear bulkhead of the dryer behind the drum. Unplug the dryer and take it outside. Set it on a truck tailgate or a table.
More Here
May 21, 2011 | GE Dryers
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
Need serpentine belt diagram for a 2005 Chevy Aveo
One doesn't need a serpentine belt diagram to thread a new belt to the pulleys.
Just note which pulleys are smooth and which have grooves in them, and 'thread' the belt loosely around the pulleys in a fashion where the smooth part articulates with the smooth part, and the grooved inner part articulates with the grooved part.
Do this until the last pulley is the tensioner pulley, which can have its tension released with a breaker bar.
Aug 19, 2010 | Chevrolet Aveo Cars & Trucks
DRYER WONT' HEAT #DDE7200SBLWW, VENT IS VACCUMMED OUT, STILL NO HEAT..CAN YOU HELP?
Unplug itb8186b9.jpgf75ef33.jpgbcd153e.jpg4f353dd.jpgCheck the heater element39cd6ae.jpg8f45608.jpg
Nice vid about homeowner repair of a plain Jane GE dryer:
More good stuff HERE
Aug 08, 2010 | GE Dryers
New Belt and pully-wont activate swith to start dryer
The main cause of this is improper bely routing. Click here and verify that it was routed properly.
SG
Apr 07, 2009 | GE Dryers
Need some assistance with a DDE7200SBLWW/model ge dryer
If the dryer is getting hot but not turning, you most likely need a new drum belt. If the belt is ok then you will need a new motor.
Dec 03, 2008 | GE DBL333EA Electric Dryer
GE DBL333EA Electric Dryer Logo
225 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
