Question about Amana NAV8805E Top Load Washer
My washer model nav8805e will run for 30 seconds or so and shut off. Then all the lights flash 2 times and then returns to one light on the reg cycle. It keeps doing this no matter how many times I try. I have unplugged it for 2 days hoping it would recycle or something to no avail. Could you please give me a little insight to what the problem may be and how I might repair it. Thanks so much for your time. Lynne
3 Suggested Answers
  • 2692 Answers
SOURCE: Washer starts, runs a few seconds and stops,does it over and over
Sound like the internal overload on the motor may be going out .Thsi is usuaklly due to bad or worn bearings. If you know anything abotu electricity,take a voltage reading at the motor whe it is in the run cycle(when it stops) If you stil have have the 110Volts to the motor then the motor is bad and need to be replaced.If you do not then you wil have to look elsewhere for the problem.
Posted on Dec 14, 2008
  • 6277 Answers
SOURCE: I have a tandem 3000 front load amana washer, it
My normal answer about new machine problems is - (Contact the vendor!!! I assume it is still under some sort of guarantee/warantee? You can nulify any guarantee if you attempt to fix problem before contacting vendor.)
BUT it might be something like poor water feed so check that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back. Although it is new it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses.
Otherwise I'm sorry but it looks like you have to wait for the manufacturer's repair centre to sort it out.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Sep 09, 2011
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Jun 26, 2016 | Zanussi Dishwashers
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - Community Forums
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Cae2743bq will not turn on all lights on and lid lock is lit up
Try this, worked for me! :)
New WHIRLPOOL Top Load Washer
Model #'s CAE2743BQ, CAE2763BQ
Cycle Selector Knob key dance: [CCW=Counter Clockwise and CW = Clockwise]
Start On "NORMAL"
1 step CCW (Left)
2 steps CW (Right, Right)
1 step CCW (Left)
1 step CW (Right)
Stay on "HEAVY DUTY"
(If unsuccessful LEDs will not flash, and you must return the selector to the Normal Cycle position and
wait 4-5 seconds before retrying. )
If you are successful in the process, all LEDs will be flashing
Toggle between HEAVY DUTY and NORMAL until ONLY the RINSE light is on, then press the
START button for about 30 seconds. Machine will then enter CALIBRATION mode for about 2 - 4
Sep 01, 2013 | Whirlpool Washing Machines
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Ammana nav8805e
If your washer fills but the timer cycle doesn't advance-replace the timer. If your washer fills the time cycle advance, and still not agitating your agitator is at fault.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Model 17019 ~ Clean light flashing
try pushing heat dry then normal back to back three times. then start. this should clear it up but only temporarily. you have a problem in your heat element or your control board.
Mar 21, 2007 | Kenmore 24 in. 17019 Built-in Dishwasher
Amana NAV8805E Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
