Question about HP OfficeJet 6110 All-In-One InkJet Printer
Every power up requires set up
Hi all,
Every time I switch on my 6110, it requires me to set the language, country and print an alignment page...
Any ideas on what I could try here?
Thanks!
Try resetting the unit by holding # and 6 while plugging the unit back in after unplugging the power cord.
Posted on May 16, 2008
  • 21 Answers
Theres usually a small battery on these mfp machines which is soldered onto the formatter board, this would need replacing. Bes is don't turn the machine off.
Posted on May 11, 2008
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Difficulty sending faxes, allign cartridges
Have you tried to uninstall the existing driver and reinstall the driver back to check if that works.
Aug 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Green light flashes , but the printer will not startup disply only shows hp logo
Issue seems to be with the hardware of printer.
You can try following steps to reset it to "factory default settings"
1- Unplug the power cord from back of printer when printer is turned on
2- Wait for 30 seconds.
3- Press and hold # and 6 on printer while plugging the power cord
4- Printer may shut off itself
5- Press power button to turn it on
6- Select country and language
7- It will clean and align itself. May take 7-9 minutes
8- It will print an alignment page, place the alignment page on scanner glass and press ok
Wish for all success..
Dec 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
A test page keeps on printing everytime the printer is switch on
The printer is printing alignment page. This will be printed if the printer was reset or if you have changed the ink cartridges. We need to complete the alignment process.
1. Place the printed page on the scanner correctly.
2. Press scan button on the printer.
3. The ON light will start blinking, wait until the ON/OFF light stops blinking.
4. Now the alignment is completed and it should not print anymore untill next cartridge change
Thank you
Rizwan.
Feb 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 printer
The issue that you are experiencing might be due to various reasons.
The most common reason is an ink cartridge that has one of the following problems:
1.One of the print cartridges is low or out of ink. Black and all three colors must available.
2.The paper has already been printed on or is colored paper.
3.Protective tape on a new print cartridge has not been removed.
4.Contacts on the print cartridge are not meeting the contacts in the print carriage correctly.
5.Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
6.The print cartridge is defective.
Please check the same and try the below given instructions to get the issue resolved.
Using a clean, dry lint-free cloth (a coffee filter works well), wipe the cartridge contacts, from the top to the bottom. The contact area of the cartridge should be rubbed briskly to remove the waxy lubricant material from the gold contacts. The contacts inside the printer may also require cleaning. Using a clean, dry, lint-free cloth, gently wipe the contacts, from the top to the bottom.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings :
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Wish you good luck!
Regards,
Lawrence
Mar 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Power failure
Please follow the below given instructions to resolve the issue.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
2. Wait 30 seconds.
Note:
Please install the below firmware update to resolve the issue.
Here is the weblink to download the firmware update:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14700-3&lc=en&cc=us&dlc=en&product=79480&os=228&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Instructions to install:
1. Please scroll down the web page and click on "Download only" button in that page.
2. Click on " Save " and choose desktop on the left side of the new window (which is opened when you click on Save).
3. Click on OK.Now Double click on the file that you have just downloaded.
4. Then click on " Run ".
Regards,
Lawrence
Nov 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Bottom Margin Cut Off! :(
Your printer prints Letter format. Set the printer to A4 standard printing. As I remeber this tab is in the printer in the country/region section. Select your language and as a country select the Cech Rep. Is one of the countryes that uses A4 standard
Nov 15, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Plz Help my Printer
I understand that you are receiving the message to align print cartridges when ever you print.
This happens due to various of reasons.
Below are the possible causes of the issue that you are experiencing with.
So, make sure that ink cartridges have sufficient amount of ink and are of genuine HP should not be refilled or remanufactured.
Clean the cartridges by following the below given instructions:
Align the print cartridges by following below given instrucions:
To align the cartridges from All-in-One
1. Press Setup.
2. Press 5, then press 2. This selects the Maintenance menu, then selects the Align Print Cartridge option. A page prints to confirm alignment. You can either discard or recycle this page.
Even if the issue persists, bypass the alignment by following the below given instructions:
Press Enter and Setup simultaneously when align message is prompted on the All-in-One.
2. Wait 30 seconds.
Note:
Regards,
Lawrence
Nov 04, 2007 | HP PSC 950 All-In-One InkJet Printer
Cartridge alignment
1. Press Setup.
2. Wait 30 seconds.
Note:
Regards,
Lawrence
Nov 01, 2007 | HP PSC 950 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
43 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
