Question about Fisher and Paykel Refrigerators
I have an activesmart refrigerator with freezer at thge bottom. The rubber inside the freezer door doesn't stay in possition. What can I do?
  • Fisher and P... Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
F&p E331T constant beep
The ActiveSmart system that manages the fridge will beep when there is fault, and the amount of beeps will indicate the fault code.
To understand the fault code, a technician would also need to know the version of activesmart, and the product ID on the grey label on the bottom right of the fridge.
Dec 02, 2016 | Refrigerators
My frigo is not colding much and the freezer not freezing
Adjust the thermostat to a higher number for a colder setting. You cannot turn off the refrigerator without turning off the freezer too.
Sep 14, 2015 | Fisher & Paykel RF170ADX4 ActiveSmart...
SOME TIMES LEKING WATER FROM THE BOTTO OF THE FREES
Could be a clogged drain line. In freezer just below the evaporator coil is a hole that drains to a pan usually can be cleared with hot water and a turkey baster
May 06, 2015 | Fisher & Paykel Paykel RF201ADX5 RF201ADX5...
I have the bottom freezer w/2 doors up top....light inside will not go off and has started to melt some of the plastic pieces. How do you remove the light bulbs so the darn thing doesn't burn...
There should be a light switch inside each compartment, depress them with the door open one at a time, locate the bad switch and disconnect it. You can remove the bulbs too. Most of the problems with bottom freezer are the door, they seem to not get closed properly and they get heavily frosted, once frosted they seem not to close correctly and cause the lights to remain on.
I would look for the problem with the door closing or the door switch failing.
Aug 28, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerator door will not stay closed
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Sep 25, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer door will not stay closed when closing refrigerator door
To replace it Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Sep 04, 2009 | Refrigerators
We have cracks forming in an 8 inch section of
you can use a hydraulic adhesive or Automotive door trim glue ( yellow) works great too these are made for extreem weather conditions ,
Aug 29, 2009 | Maytag MTB2156GES Top Freezer Refrigerator
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
