Question about Refrigerators
The thermostat is not cooling the fridge sufficiently despite the dial being turned to maximum 7.
  • Chickenlamb Jun 05, 2008
    I have three zone wine cooler from Transtherm. The lowest area of the cooler has frost build up and the other zones are not cool. The thermostat temp is at 70+ or -
  • 828 Answers
Is the compressor running continuously? Check the condenser and clean. If the condenser is plugged with dust you will have this problem. The thermostat only controls the compressor operation. If the compressor is hot and the freezer has no frost You need to call a service tech. If the condenser is found to be plugged with dust, shut the unit off, clean it and allow it to cool down before restarting it.
Posted on May 05, 2008
I have a tall smeg fridge freezer. Freezer compartment working perfectly. Fridge not cooling despite all lights being on. I've switched it off then on, turned the thermostat down, then up again...
Hi Evelyn,
Has the freezer been defrosted lately? Perhaps a buildup of ice will not let the refrigerator cool sufficiently. Try this and let me know how it works out for you. If it does not have a self defrosting cycle on it, it may take some time, just do not use a sharp object in the freezer as this could puncture the freon lines and that would render the unit useless.
Joe
Sep 21, 2011 | Smeg Refrigerators
The refrigerator is not cooling enough. Even though I turn the dial up to the maximum 7, the temperature will not go below 50 degrees. I need to maintain a temperature below 47 degrees.
There could be two reasons for this
The thermostat is not working properly - replace the thermostat
There is a small refrigerant leak and the fridge cannot get cold enough - you will need a technician to find the leak and regas the fridge
Mar 30, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My LG fridge/freezer is approximately 7 years old. It has worked fine until two weeks ago, when I noticed the fridge section wasn't very cold and the freezer only seems to be freezing items on the bottom...
Most of the components are within the fridge unlike the older models and at the bottom of the fridge. It is possible that the fault is related to a thermostat or a auto defrost timer issue.
Since the fridge is not defrosting there is heavy frost that is preventing the fan to blow cold air and cool efficiently .
You will need to check the thermostat, auto defrost timer ,heater to confirm the fault.
Finally the poor pumping of compressor or low gas pressure can also reduce cooling.
check the compressor motor speed, check the capacitor.
Mar 29, 2011 | Refrigerators
The cooling is not sufficient. I am running the fridge at the maximum and yet every thing is defrosting in the freezer. In the fridge part also the problem is the same.
thermostat defective/Short of gas/chocked/no gas.
1. Thermostat is malfunctioned-Replace it. 2. Check amps of the fridge if run amps is less than as specified, it's gas leak. 3. Keep your arm on condenser line. If it's warm, gas is there. Check slight whistling sound in freezer. If not system chocked.
For gas leak find leak and arrest it. Then vacuum and do gas charging.
For chocked system, release all gas and flush out the system. Replace filter drier and vacuum and do gas charging. Helpful?
Jan 31, 2011 | Whirlpool Refrigerators
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
I have a brand new hoover black fridge freezer - only 3 days old and the freezer section is fine but i cant get the fridge to get below 7 degrees it makes no difference if i turn the dial to low or high....
The ideal refrigerator temperature is 35° F (1.6° C). You're not hugging the danger zone like you would be at 40° F (4.4° C), and you're distancing yourself sufficiently from 32° F (0° C) that you don't freeze half the stuff in your refrigerator.
Not cool enough!
Nov 01, 2017 | Hoover HCA390K Bottom Freezer Refrigerator
Defy Fridge temperature dial is confusing - which way is colder?
0 = off, 1 = cool, 2 = cooler, ..... 7 = coldest.  0 - 7 Nothing to do with the degree the fridge is set to.
Jan 07, 2009 | Refrigerators
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
