Question about Craftsman Garden
I was working on my deck for an hour until i ran out of gas, i turned off the washer on off switch, i re-filled with fuel, pulled the starter, did not start, pulled again, started but turned off and then i was not able to pull on the starter again. how can i fix it? thanks for your help!
    Problem Solver:
  • 18 Answers
Check your carbs the may clogged
Posted on Aug 25, 2010
Start a Camry after it ran completely out of gas. Does the fuel pump fill the line when tank is filled & key turned?
Your fuel pump is located inside the gas tank and every time you turn on the ignition switch the fuel pump will start and pressurize the fuel line for a regular starting cycle. But, since your fuel lines are totally empty. I would turn on the ignition for a 20 second period. then turn it off for a few minutes to let the system fuel system reset and then turn the key back on for the same amount of time and do this for at least 4 times. Each time you turn on the key if you have waited long enough to allow the fuel system to reset. This will in the end fill the fuel lines and fuel rail on the engine and then you should be able to crank the engine and start ok. do not crank the engine until after you have cycled the ignition key about four times and wait about 2 minutes in-between cycles.
Have a nice day, regards, Dennis
Mar 02, 2015 | 2001 Toyota Camry
How to start Echo ppt-266
Fill with correct fuel/oil mix. turn switch to I. Pump primer bulb 4-5 times. Turn choke on. Pull starter until engine fires. Turn choke off. Pull Starter until engine runs & allow to warm up for 10 secs before trying to engage throttle. If it doesn't start after 3-4 pulls with no choke then try same sequence again. May have to use 1/2 choke after engine fires. If it still won't start then something is wrong with it & it will need to be checked by a service agent.
Jun 19, 2014 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Mccullough chain saw
Some saws use the compression stroke to pressurize the oil tank for auto oiling. If let set long enough the oil will flow backward into the engine causing this.
May 28, 2013 | Garden
My 05 Yamaha Grizzly 660 will not start. In my limited troublshooting practice I looked at FUEL, FIRE and AIR. Here is the fault, the engine will not start. I checked wires/fuses, plugs, fuel lines and air...
Sounds like you have a stuck float needle in the carbs (2). Usually after a few days with gas in the carb they will free up, you could 'knock' on the carbs with the plastic end of a screwdriver to help free them up. If not, turn off fuel, drain the carbs and fill them with carb cleaner for 24 hours. Redrain, attach fuel lines and turn the gas back on. If still no start it's time for a rebuild...
Mar 05, 2017 | Yamaha 2005 Grizzly 660 Auto 4x4
I have a new Weedeater One 190cc 26in blade riding mower and during my 2d use it ran for approx 15 mins and I shut it off and when I attempted to restart the starter kept turning but would not start. I...
Check for spark and gas. If adding a few teaspoons of gasoline to the cylinder allows the engine to run for a few seconds, then you know that the ignition system is fine, but there is a blockage of gasoline to the engine.
Aug 21, 2010 | Garden
My 1999 wind star ran out of gas. After filling it it would not start. I checked the puel pressure and it was 2psi. I replaced the fuel pump screens and inline filter. I pulled the fuel line off after the...
It could be 3 things: 1) Your battery needs to be replaced. If your battery is new or has already been replaced it could be 2) Your starter or 3) Your alternator.
May 20, 2010 | 1999 Ford Windstar
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Jun 07, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
158 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
