Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
Need a new motor for irrigation 1 1/2hp.... recommendation?
  • 30 Answers
Www.poolpartsonline.com/
Posted on Aug 26, 2010
Where do I get a new gear box for traveling sprinkler Orbit
Once again a couple simple GOOGLE searches...
Here is the item on the ORBIT website.
Orbit Irrigation Traveling Sprinkler Motor Assembly
I've never bought anything from these companies so I don't know how legitimate they are. Use at your own risk!
Orbit Traveling Sprinkler Motor Assembly
Aug 02, 2016 | Orbit Garden
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
My in-ground pool pump...Sta-rite 11/2 hp...leaks at the outlet fitting. Changed fitting twice, using teflon tape as recommended...still leaks.
I don't recommend Teflon tape as it places outward pressure on the pump and can cause the pump body to crack. and if that happens the pump body will need to be replaced. I use black RTV silicone. smooshing it into the threads of both fittings and hand tightening the fitting.. then the glue the pipe as normal
REMEMBER to prime the pump after any pump repair !!
Teflon tape works well on metal pump like well and irrigation, they are a high pressure pump and are generally cast iron tanks.
Jay the pool pump motor repair guy longwood Florida 32750
Mar 14, 2012 | Sta Rite Pool & Spa
The clock motor appears to have stripped a gear. The top several gears are turning, but not the lower gears. The unit is a year old. Can I purchase a new motor? Thank You
From what you are saying I don't think you need a new motor I think you need to replace the unit itself.
To answer your question you can purchase a motor from intermatic the last time I checked they are about half the price of a new timer. Good luck and thank you.
Feb 26, 2011 | Intermatic R8806P101C -...
The yellow time dial has stopped turning and the auto switch cannot activate the sprinklers
If I understand correctly, the manual override does not work, and the clock dial does not turn.
It seems odd that both things would happen together. Usually the clock motor stops but the manual override still works.
Check that your timer has electricity. Check your breaker. It sounds like the electricity is off.
Does your manual override snap clean and crisp, or it it sluggish? If the manual override is sluggish, the timer mechanism may be rusted.
Snap the timer out from the box and look at the condition of the gears, and the override lever. If the timer is rusty and the manual override does not snap clean and crisp, then the timer needs to be replaced. Buy a new timer and swap out the insides without changing the box.
You might need a clock motor
Snap out the mechanism and get the number off clock
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
Nov 09, 2010 | Intermatic R8806P101C -...
The clock does not move forward. If I manually turn it, then it will work and turn on the system where the pins are. I haven't tried anything to fix it because I don't know where to start. Intermactic...
Sprinkler and irrigation timers are 14 day.
That being said, it sounds like the clock motor is bad.
Snap timer free from box and tip out to see clock motor located on back of timer.
Get the number off clock motor
Nov 08, 2010 | Intermatic R8806P101C -...
Wire wayne 1.5 hp irrigation motor.
Your wires- Black=hot, White=common, bare copper wire=ground.
Motor wires- Black=hot, White=common.
Connections: Black to black, white to white, bare copper from line in to motor frame.
The wires from the motor should have been designed to carry the power load. Heavier wiring is always an option, to a point.
Regards, --W/D--
Jul 20, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Meyer CT20 pump, 220volt seized (does not run)
yes it has seized,the brushes are most likely to far gone to fix.you need a new one.yes store inside in the winter months!
Jul 14, 2009 | Plumbing
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
66 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
