Question about Sony KDL-32U2000 32 in. LCD Television
My Sony KDL32D3000 TV has stopped showing a picture and only has a white screen with thin coloured lines, except for the right centre which has something like a negative picture. Can you tell me if it is repairable? Thanks
SOURCE: sony pfm 42b1 negative picture
I have a Sony PFM-42v1 and it does the same thing, look in your tv menu for picture inversion, usually under screen saver. What it actually does is reduce the chance of screen burnin. By reversing the image it sort of resets the hot areas, brightest colours and the cooler areas being dark colours, switches them around ( negative ). This cools the hot spots and heats up the cold spots.
There should be a option to turn it off, mine and I guess yours as a default is ON, mine has the ON, timer and OFF options.
Hope this helps, please let me know if you need more info.
russell
Posted on Mar 12, 2009
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
SOURCE: I have coloured vertical lines covering my Sony
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Posted on Jan 29, 2010
SOURCE: My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Posted on Oct 04, 2010
  • 1779 Answers
SOURCE: hi my 46inch sony led
Take it in to a service company. It's possible that your LED display has gone bad.
Posted on Dec 27, 2010
Thin white line on right side of tv intermittent
The only easy hope here is centering is off just slightly to the left and the line etc will show on certain scenes and or channels.
Not sure if this set has a centering in customer menu or maybe in the tech menu---a call to sharp might answer this for you.
Aug 28, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Hi sir.I have a sony Bravia tv KDL-40Z4500.My tv screen is showing Bar of colourful lines from top-to-bottom verticle close to centre of screen and width is 8cm.You can still see tv picture either side of...
Hi Djmojoey,
Your question is probably best answered by Sony...in the meanwhile, I found a manual for you to review the troubleshooting.
https://www.sony.co.uk/electronics/support/res/manuals/4138/41385145M.pdf
In addition, the Sony website page states some features that are discontinued as of March 2017. Support for KDL 40Z4500 Downloads Manuals Tutorials and FAQs Sony UK
I hope this helps at least some.
If you do not have experience discharging the tube, PLEASE BE CAREFUL!!!
Jul 06, 2017 | Televison & Video
My sony tv displays the screen on three differen colors almost like 3d picture already tried to do the self adjustment in front of the tv by the menu button what can i do now
pls. this problum is convesouns Adjesment on Remot cantrol
PRESS MENU button and menu on the screen
DOUN Arow to bottom and Adjest converson left to right and top to bottam the cross line maching 3 colour line and cross line is total white is ok see the pictur is ok
Oct 04, 2009 | Televison & Video
Had horizontal Lines replaced now have error 21 xray circuit
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Severe vertical jitter on picture, horizontal sides of picture ragged
Replacing the TDA4950 cured the fault
White line down centre of screen (top to bottom}
Replace C805
Nov 24, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Samsung TV
Hi.
Just read your list of problems The first fault (Diagonal lines & picture collapse from left & right) Sounded like either A poor connection or dry solder joint either on scan coils or scan coil plug / socket on main pcb.
If this were the case the engineer that called out should have spotted this & sorted it very easily. But you say it is still the same so what did he do ?
Did he give you a reciept with break down of what he did ? If yes please post it here for me to go over.
The sound problem you describe has thrown me a little so could you please post your tv model number on this page so I can see if this is a stock fault.
The static shocks you are getting is relatively normal & not a problem unless you are getting them off of speaker grilles or even tv casing if it is silver in colour.
I am UK based & have access to samsung technical but I will need your tv model number.
http://dysonmanuals.inc.io/
Chris.
Oct 30, 2007 | Televison & Video
LG colour TV RI32CZ10RX problem with picture
My LG tv has suddenly got a problem with the picture. Whilst watching the tv with no problems at all, the picture was suddenly reduced to a thin vertical line down the centre of the screen and an awful smell seemed to come from the tv There is a short ckt in your tv in horl. section. 1 isolate power from horizontal section. 2 check for normal output from power supply. 3 check parts in horl output section a hor.output transistor b diode & cap in h/output trnsformerckt. c check for print. d if all are ok check for eht transformer. e if every thing becomes then reconnect hor output section supply. f put on the set.
Sep 23, 2007 | Televison & Video
Orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Sep 15, 2007 | JVC AV-27D302 27" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Audiovox AVT 1598
The vertical output IC or the vertical circuit is whats at fault. its all solid state and im sorry to tell ya that its not a user replaceable part. This set is probably not worth the repair it would take to get this set working again but please if you like ask a ;ocal repair shop what they thought about this problem.. Good Luck and please dont forget to rate this thread
Nov 11, 2006 | Audiovox AVT1498 TV
Sony KDL-32U2000 32 in. LCD Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
