Question about Liquid Video A170E101 Monitor
Need power cord for monitor 19Volt, 2.6 amps Where can I buy one?
    Sergeant:
  • 223 Answers
I would look on ebay if it has a special plug for under 20 dollars. Most monitors use the same plug cable as a computer though, so i have rarely run into that problem. Lots of old computer plugs around. Check your local computer shop. Take the monitor in with you. At my shop we had a whole box of them from dead monitors / laptops. most of which are 19V. If you want new, i believe Targus made a multi end power adaptor http://www.targus.com/us/product_details.aspx?sku=APA68US cheers
Posted on Aug 24, 2010
How can i find a power cord to fit this monitor? The one I have is not getting power to it . It was tested by Best buy.
Most monitors have the same type power cord. You can order them cheap off of Amazon and eBay.
Heres on that should work: http://www.amazon.com/Cables-Go-03134-Universal-IEC320C13/dp/B00005113L/ref=sr_1_1?ie=UTF8&qid=1298845316&sr=8-1
Feb 27, 2011 | Envision EN 9110 19" Flat Panel LCD...
Someone gave me an old Sylvania monitor (L15) Model no. PD-70FA but the 12V DC power cord is missing. It is not a standard type of powervcord and none of the stores I've been to (Staples, Office Depot,...
The power chord for this monitor is attached to a power adapter which converts mains voltage to 12 volts.
Check the power label on the monitor for the amp rating of the monitor and get an adapter that has an output of 12 volts and with the amp rating on the label or higher. Make sure the 0.3" power plug fits the monitor.
Feb 26, 2011 | Computers & Internet
I need a power cord for a Scanport 1920S 19 in. Flat Panel LCD Monitor
It uses a "standard" power-cord.
Look in any "Thrift Store" or "Dollar Store",
or buy at any small "mom-and-pop" computer-store -- they probably have a box-full of them.
Don't pay more than $2.
Oct 11, 2010 | Scanport GL-1920S 19" Flat Panel LCD...
I need a power cord for a balance CM2019 lcd monitor
You can buy a power cord at any Lowes, Home Depot, Radio Shack or Best Buy. The power cord is not unique to the monitor.
Hope it guides you :)
Jul 14, 2010 | Balance CM2019 19" LCD Monitor
My monitor will no turn on what do i do
1. Verify power cord is plugged-in and supplying power to monitor.
2. Verify Cord in between CPU & monitor is responding. (if it doesn't it will display Dell logo on dell monitors).
3. Press Power button and see LED turns green.
Sep 12, 2009 | Dell Computers & Internet
Monitor will not turn on- no power
Look for a reset button on the monitor back. Make sure there is power at the receptacle. Check the power cord to make sure if it good and power is actually getting to the monitor. If you find the power cord is good, then you probably need to just buy another monitor. Cost more to fix a used one than to buy a new one.
Sep 08, 2009 | Gateway FPD2275W LCD Monitor
19' Westinghouse Monitor - Intermitent come on.
The problem is either with the power cord itself (especially if it is connected to the monitor such that it stays bent all the time), or the problem might be with the socket into which the power cord plugs in the monitor. The solder joints fixing the power socket to the circuit board & connecting the power terminals to the circuitry usually tend to get loose after some period of usage either due to mechanical stress while connecting/disconnecting the power cord to/from the socket, or due to high currents passing through these joints continuously.
My suggestion is to test with a power cord which is known to work without problems. If this did not fix the problem, then the monitor will need service (monitor needs to be disassembled to a degree that permits re-soldering of the power socket's terminals to the circuit board).
Jul 19, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
I need a power cord for the monitor
It should be the same type of power cord as for a computer so you can take one from a old computer or buy one at your local computer shop
May 12, 2009 | Scanport 17" LCD Monitor
I need a power cord for a mag innovision lcd monitor
Dec 26, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Need to buy a electric cord for a Flat screen monitor. Model # FPD1775W & part # 7010662R. Please give retail price and where I could get it buy.
This monitor uses a standard 3 pin computer power cord you can get one of those easily at any electronics store for $5 or so
staples sells them as does radio shack depends where in the world you are
Aug 21, 2008 | Gateway Computers & Internet
Liquid Video A170E101 Monitor Logo
Top Liquid Video Computers & Internet Experts
Marcin
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
