Question about Maytag Refrigerators
The lights burned out in the refrigerator. I replaced the bulbs, but there is still no light.
  • 86 Answers
I would check the door switch. I believe that's were your problem is.
I hope this helps you. Please feedback. Thank you.
Posted on Aug 24, 2010
My 19 year old kitchenaid kbrs21k refrigerator still works fine BUT when i recently crammed too much stuff onto the top shelf i must have broken the plastic light cover which fell on top of the light bulb....
Take the bulb out and check the continuity. Then you should know if there is a fuse that needs replacing. If all is well make sure your new bulb doesn't have a bad element.
Dec 03, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Maytag model MSD2651HEW replaced two refer side lights. New ones will not light
some of the bulbs you buy at the stor the sucket pease is not long onoft try to scruit more or by them from a applice parts stor they little longet and make good contact
Feb 21, 2012 | Maytag MSD2756G Side by Side Refrigerator
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
The four refrigerator lights on my Viking VCBB363 refrigerator do not come on when the door opens. One of the 40W, cylindrical bulbs is black, and obviously burned out. Do I just need to replace it? Unless...
They are not wired in series. Replace the bulb burned out and check the door switch of unit. If that is not working neither will any of the bulbs.
Sep 12, 2017 | Refrigerators
Burned out light in refrigerator. Replaced with
lube the light base with silcone and tighten . it has a rubber boot to seal it and it sometimes won't let the base of light tighten and touch contacts. **** ..
Jan 10, 2010 | Refrigerators
GE GTS20ICNCC Refrigerator light bulb burns out quickly
Use the correct wattage bulbs. If they fail often then you may need to get it checked by an electrician.
Filament bulbs easily burn out. What you can do is to buy cheap bulbs and replace as soon as they burn. This is the problem which is why tube lights and LEDs were invented!
Sep 07, 2009 | GE Refrigerators
Lights is refrigerator side stopped working. Seems to be cooling, but no lights. Freezer light is okay. Changed out bulbs, still not working. Is there a fuse for lights?
may be the light switch or try this unplug refrigerator on screw bulb look in the socket there is a flat side in it the center get a flat screw deiver pull it up a little put back bulb plug unit if it dont light change switch
Mar 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Mar 04, 2009 | Whirlpool Refrigerators
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
15 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
