Question about Philips Magnavox 51MP392H Rear Projection Television
Convergence problem - Philips Magnavox 51MP392H Rear Projection Television
  • Philips Master
  • 8,617 Answers
Install the Phillips DPTV305-DPTV345 convergence repair kit which is available from www.tvrepairworld.com the kit contains the ICs , Resistors and the CD with repair instructions.
Posted on Aug 26, 2010
Is having a local newspaper start placing video about news events on its website an example of media convergence
Anon, I think this could be looked at as a type of media convergence. Check the attached links on media convergence. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What are examples of media convergence
Converging Media Home
media convergence
What is Media Convergence
Jun 03, 2013 | Computers & Internet
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
How do I adjust the convergence?
3_24_2012_6_00_06_am.jpg This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Feb 03, 2011 | Panasonic PT-51G36 51" Rear Projection...
Convergence issues
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 20, 2009 | Mitsubishi WS48511 48" Rear Projection...
Picture color ghosting
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 20, 2009 | Toshiba 50HX70 50" Rear Projection...
Convergence problem--blue lines won't line up
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 19, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a sony Projection TV KP46WT510 convergence issue. How can I fix it? I see fusy picture with red and bleu double picture. I tried the convergence fix in manual and it shows the issue but could not...
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Jun 13, 2009 | Sony KP-51WS500 51" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
Manual Convergence
your convergence ICs have failed. You can get the convergence repair kit for your model at the following link which contains both convergence ICs and all of the feed resistors, plus the kit contains step by step instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Philips 60PP9202 60" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
