Question about Car Audio & Video
I recently replaced a stock radio in my mothers car, a 2004 subaru forester. I have done this before in my honda by cutting and splicing the wires and using no wiring harness. except this time i thought all was good, until the next day when we noticed the dash lights are all not working. no idea how this could have happened. the fuses are all good, so im not sure what else to try. any ideas?
    Problem Solver:
  • 5 Answers
You may have spliced into the illumination wire as your auxillary power. use a volt meter to check and see if either of your power wire recieve 12.0 to 13.8 volts when you have your headlight on. if you do then you have used the wrong power wire
Posted on Aug 24, 2010
I have a 1999 Subaru Forester. I recently had the ac/heater blower motor replaced. It was only blowing on high so I replaced the resistor. Now it is blowing the fuses. Any suggestions??? Thanks
check that the wires for the motor are on correctly and that the loom has not jammed and cut when replacing the motor. There is a dead short in the wires after re-assembly of the system
Oct 06, 2014 | 1999 Subaru Forester
How do you remove cd changer from an 06 forester
Is it in dash or the multi in back
unscrew dash plate around radio use a magnetic screw driver because the screws are in the two front vents once thes removed the dash radio plate should pop off without force exposing radio behind unscrew that unplug wires pull rest the way out
now the advice
make sure if your replacing with aftermarket make sure your wire leads are connected correctly no splicing of main wires in dash thats nono trouble as wires now have multifunctions to them it should be simple as plug and play
May 09, 2014 | 2005 Subaru Forester
Wiring diagram subaru forester xt my04
I'm assuming you mean 2004 Subaru Forester:
2004 Subaru Forester Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Dec 28, 2013 | Car Audio & Video
How does one install a block heater in a 2004 Subaru Forester?
Aftermarket block heaters can be bought and some you just splice into your lower radiator hose.
Oct 14, 2012 | 2004 Subaru Forester
2000 subaru forester/wiring for a trailer
The easiest way is to go to any RV dealer, or most Autoparts stores and buy an adapter. They plug in to your existing wiring harness under rear of vehicle and then you simply plug your connector in to it from there. Saves trying to figure it all out and cutting or splicing into your existing wiring and possibly causing problems later.
Nov 12, 2011 | 2000 Subaru Forester
Help re: flat battery on the subaru forester 2004 - can I disconnect and put in a replacement. What are the precautions? How can I ensure I maintain the security and radio settings etc??
If the battery is dead,no power what so ever,then it will not matter,but a aux.power supply needs to be put on the vehicle to ensure no memory loss to all settings,and the computer.Another battery with jumper cables on the cable ends will ensure no memory loss,but it has to be done gracefully to prevent any shorting out.A plug in a cig,lighter with 12 volts would be idea,make sure the cig plug is hot even with the key off.
Jan 26, 2010 | 2004 Subaru Forester
2004 Honda Accord Radio fuse blows
There was a recall for the 03-04 Accord radio. It had faulty circuitry that caused the screen to go dim. Check with Honda to see if they'll still honor the recall.
Mar 12, 2009 | 2004 Honda Accord
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
