Question about Sony RDR-VX530 DVD Recorder/VCR
My problem is that the Recorder shows DVD 1 and I cannot get it to go to DVD 3, I press the Enter on the Remote, and the Number 3, and the recorder stays on DVD 1. Any other suggestions on how to reset the Remote?
  • 10,594 Answers
There is button on lower part of dvd remote, Mode 1-2-3
Set that button on mode-3 to communicate with dvd recorder.
Posted on Aug 24, 2010
  • gkpatrick Aug 25, 2010
    On my remote, I do not have a mode-3 button, any other suggestions?
On my Panasonic blu-Ray DMP-BD871 the screen says set 1 when I press the remote... Why is this happening I can get on to use my blu-Ray at all
Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players.
When you press a button and the display shows [ CHK REMOTE # ] or [ RC# ] or [ SET# ] it means that the DVD recorder and the remote control are not set to the same code.
To set the remote control code to that of the DVD recorder, press and hold [ ENTER ] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
May 24, 2014 | Televison & Video
Dvd recorder
The following should give you access to a service menu containing controls for macro-vision and region coding. You can change the regional settings from there.
1. Set your player to Standby
2. Press Title, Clear and Power
Jul 05, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Remote is Stuck in DVD 1 mode
I had this same problem (DVD1). Resolved as follows: With DVD player on, pointed remote at DVD player, pressed and held the 1 key and then pressed and held the enter key (both at same time) until I saw the DVD1 on the DVD player display disappear. Now everything works.
Jun 23, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony RDR-VX530 DVD Recorder/VCR Logo
48 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
