Question about Refrigerators
Jennaire side by side refrigerator
Power was out three days due to weather-hooked refrigerator up to a generator and freezer side works but refrigerator side does not get cold. I turned the switch inside off and then back on in case it needed to be reset. the refrigerator is about 9-10 years old
  • suep08 May 05, 2008
    the fridge is not cool. there is snow on the back of the freezer section, so it must be a defrost problem right. but how do I fix that?
  • 828 Answers
Check the back wall of the freezer for snow on it. If present you have a defrost problem which will reduce or cut off air to cool the refrigerator section.
Posted on May 05, 2008
I have a luxury JennAir side-by-side stainless steel refrigerator (about 3 yrs old). 42" or so wide. I've had significant ice build-up in the freezer, around the fan unit. I have just turned the unit...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your refrigerator. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number or email address, and model/serial number, and I would be happy to try to help resolve the situation with your appliance.
Oct 13, 2010 | Jenn-Air JSD2488G Side by Side...
Hello I own a profile refrig. and the ice maker stop working three days ago. Since then food is not getting cold on the freezer side and refrig. side. Could it be a thermostat?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
JCD2289AES jennair fridge refridgerator side is not cold but the freezerside works
The fridge side is not getting enough cold air from the freezer side. This could be due to a few things. The vents from the freezer is blocked, or the evaporator fan/motor has failed, or the evaporator coil is iced up due to the defrost circuit failure.
To check which is the problem you will need to empty the freezer to you can get access to the panel that covers evaporator coil. After removing the panel check to see if the fan is turning, also note whether the evaporator coil is iced up. If it is iced up, then the defrost circuit is failed. The problems usually are a failed defrost heater, defrost timer or defrost thermostat.
Aug 12, 2010 | Jenn-Air Refrigerators
My jennair refridgerator won't stop running. The motor is running constantly. Can I do anything to fix it myself?
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 12, 2010 | Jenn-Air JCD2389G Side by Side...
Both Freezer in my shed packed up at the same time is it due to the realy cold spell we are having> I have thrown alot of food away. Can anyone help sort it out .
Good day,
Any temperature below 55 degrees will cause the machine to go
out of balance. If far enough below 55 degrees the machine will reach a point where it rarely if ever runs. Thus your problem.
Frigidaire's owner manual will verify this.
Domestic refrigerators/freezers are designed to work properly at temperatures comfortable to people.
Usually 70 to 95 degrees.
Sorry I can't give you a solution better than this but it is a common complaint here in cold weather. This problem applies to all brands and models of refrigerators - freezers.
Thank you for using FixYa
Jan 11, 2010 | Frigidaire FRS23KF7AB Side by Side...
BOTH SIDES DOES NOT GET COLD
Must be either a refrigerant leak or block of refrigerant. or even due to excess frost formation in the refrigerator often results in lesser cooling.
Please get habituated to defrost the unit at least once in three days.
Test the pressure of refrigerant to decide on recharging the refrigerant.
Jul 13, 2009 | Frigidaire FRS26KF5C Side by Side...
My freezer is working, but refrigerator is not cooling at all.
call maytag back with your issue, if for some reason your problem is related to the recall, then they will make good on the repair for you
Jun 09, 2009 | Jenn-Air JCB2280HES Side by Side...
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
