Question about Home
Adhesive Remover I put one of those vinyl tape strips in a shower...The substiture for caulking, Well it didn't work out too well so I removed it. Now I got a really gummy mess of the sealant residue left behind. The shower walls are acrylic, Whats a really good adhesive remover to use .
    Guru:
  • 256 Answers
Normally a bit of benzine will do the trick without damaging your shower wals. Soak it for a while by adding benzine to a cloth and holding it in place for about 2 minutes. Then wipe away.hope this helps. Otherwize, if the benzine takes too long, you could also use some gasoline.
Posted on Aug 24, 2010
How to take old tub caulk off a vinyl floor
Check your local DIY center there are tools for doing this safely with no damage.
Jul 28, 2014 | Color Rite Color Caulk New Age Oak
Is klean strip adhesive remover okay to put on dry wall?
Yes-just let dry after-then on prep of wall after you may have to skim wall with a thin coat of drywall compound and sand smooth
Jan 23, 2014 | Klean-Strip Adhesive Remover Voc
I put the adhesive mounting disk on the windshield. Oh my god! I didn't know it 's permanent. How can i remove that ? Please help me.
Goo Gone, mineral spirits, kerosene, or if you're really ********** and want drastic results, lacquer thinner which will probably melt and take the cheap plastic vinyl and whatever else off your automobile too, but hey the mounting disk and any adhesive residue is GONE. - LOL
Jul 18, 2011 | Garmin nuvi 255W GPS Receiver
We have a Grohe faucet similar to the Concetto. It single hole mount. Recently, it became loose and no matter how much I've tried to tighten it with a rod/nut/washer underneath, it will not tighten. ...
looks like you'll have to remove it and examine it. Brass is a soft metal, I hope you've not stripped out the threads, Grohe is an expensive faucet. i fall else fails and the hreads are stripped out, I might try a tough adhesive caulk like a 3M 5200 marine grade. Apply liberally from the bottom. let it set firmly. Perhaps tape a piece of cardboard over the hole in the countertop from the bottom. this would keep the caulking from falling out before it sets. unconventional, but something to try before buying another $200 faucet. what have you to loose?
Oct 13, 2010 | Grohe 3427 Concetto Single Hole Bathroom...
How can ii remove scotch tape adheasive from a metal table
WD-40 or lighter fluid removes adhesive pretty good, or you can go to any hardware store and buy adhesive remover.
May 17, 2010 | Garden
Is there a common adhesive remover that will work on the tape strip goo that is left behined from trim attachments on an automobile body? Goo-B-Gone and Goof Off, ect. just don't work that well.
wd40 works great on alot of glues and adhesives. spray it on, let it set four a minute,start wiping off with soft cloth. wash car with mild soap and water after. hope this works ,let me know.SARG..............
Mar 14, 2010 | 2009 Chevrolet Silverado 1500
Caulk coming off in Corian stall shower
If you have the option of not using the shower for a while, I would put a dehumidifier in the shower to **** the mositure out from below. If cost is no object, you can go ahead and pull the base. The key to the caulk is to completely remove the old caulk, clean carefully and use a silicon based caulk. Be sure to let it dry properly (see caulk cure times on tube).
Dec 30, 2009 | Daltile Bathroom Accessories Resin Soap...
Dash board mount
you can buy a heavy duty double adhesive tape, or use a permanent adhesive, or mighty bond onto your dash board since the gps is still removable
Oct 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
