Question about Whirlpool Inglis IP8200 Dryer
My dryer will not start I change the fuse still wont start
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My Maytag Neptune MAH5500B wont start.We thought it was the control board so we change it.And still wont start
Have you checked the thermal fuses? The main cause of dryers not starting is the thermal fuse.
Mar 06, 2015 | Maytag Neptune MAH5500B Front Load Washer
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
Last nite mid cycle my 90 series dryer quit and now i cant get it to do anything. changed the fuses in the fuse box but still nothing . might it be the thermal fuse ?
may be the thermal fuse but here is a website that can help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 10, 2011 | Kenmore Dryers
My Kenmore Dryer, Model #66712690 does not turn on. I have checked the fuse box to verify that the unit has power. What could possibly be wrong?
if you can here the motor running then it is the belt, here is a website that will give instructions as to change the belt, the second is if it won't start:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Oct 27, 2010 | Kenmore 66972 Dryer
Tumble dryer starts then stops after 5 mins and wont restart
the thermostat near the element is your high-limit shut off fuse. look for other and change it, it would be your cycling thermostats. Your dryer is not cycling and the one you changed is doing exactly what it is suppose to do, saving you a fire. basically your dryer is overheating.
Apr 09, 2009 | Dryers
My 90 series kenmore dryer won't start
check the door switch to see if its good / if not the dryer wont start
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Fuse
thanks for the question it could be the door switch that's bad lift up the top and check the switch also make sure you have 240 volts at dryer thanks the appliance doc
Nov 25, 2007 | Kenmore 62872 Electric Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
185 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
