Question about Goodman Heating & Cooling
Condenser unit runs outside after thermostat in turned on but the fanon the inside won't come on all the time
  • 674 Answers
First turn off the power and make sure the fan turns freely by hand. Then check the capacitor. You can check it with a multimeter with the capacitor check function or take it to a heating and air supply. The other thing you can check is the device that turns the fan on and off. Some use a fan relay and I have seen some that use a sequencer to control the fan.
Posted on Aug 25, 2010
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
The furnace is running but there is no cool air. I change my filters every month and I flushed out the water lines last month.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
Aug 21, 2011 | Ruud UAKA060 Air Conditioner
Why does Blower in the inside unit continues to run non-stop? Thermostat set on Auto
Hi!!
If when the desired temp. is reached, the compressor and condenser motor (outside unit) will shut off but the blower in the inside unit will keep working when the thermostat is set to Auto, the problems could be 1 - thermostat unit defective, and 2 - blower motor starter relay defective.
Good Luck!! Don't forget to rate this post!!
Sep 21, 2010 | Heating & Cooling
I have a carrier 38YCBO48300 Over the years ithas a history of eating the start Caps Which I replace myself. This time the cap was leaking so I replaced it but the unit still will not run.The blower runs...
You must have a bad connection from either the thermostat or inside unit. Check the wire going from the outside unit to the inside unit. Look for any in-line fuses or the fuse on the circuit board.
Apr 02, 2010 | Carrier 38BRC048 Air Conditioner
Sometimes, when the inside blower shuts down, the outside compressor and fan motor continue to run for some time. Other times, when the inside fan motor is running, the outside fan and compressor motors...
The thermostat has a timer on the on- cycle (5 min delay for the outside unit and blower inside) if you are not gonna call a service guy then ( for $25) you can go to homedepot (whatever you got out there) and buy a honeywell vertical digital heat and ac t'stat.
this one doesnt require you to set it up for a particular application. this may solve your problem. but as for warm air out of the registers you need a service guy to check that
Mar 27, 2010 | Ruud UAKA060 Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Central air conditioner doesn't cool
no cooling means outside unit is not operating due to
-no thermostat signal
- condenser dirty need cleaning
- fan motor stucked 90% this the reason of noize
Apr 27, 2009 | Heating & Cooling
Central Airconditioner Heat Pump Weather King Brand outside unit continues to run even when thermostat is disconnected from terminal block base. Have to flip ckt bkr off to turn unit off. Recently it...
It sounds like you might have a short in the wiring that goes from the furnace (inside part) to the condenser (outside part). Follow these lines by hand and check to see the wire isn't damaged and shorting out.
Sep 18, 2008 | Heating & Cooling
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
