Question about American Range AF40 Deep Fryer
My American Range Fryer AF40, is lighting via the ignition dial, but when you turn the dial to increase the temperature, the ignition flame goes out. Please help as to what I can do. Many Thanks Mr Kowgie Newman EMAIL: kowgie@sky.com
  • kowgie Aug 25, 2010
    The parts list was really helpful, and the advice was so detailed. I will definately use this service again. Thanks.
  • American Range Master
  • 8,220 Answers
You need number 8
That is a thermophile. It is weak. The thermophile costs more than a thermocouple. It puts out millivolts which operate the solenoid. It is a simple system. When the thermophile gets weak it will hold the pilot but die when the solenoid is called for by the thermostat to open the gas gates so we can fry baby fry! LOL
Replace that thermophile. That's cheapest. If that don't fix it you is gonna need a gas valve.
Posted on Aug 24, 2010
  • 5 more comments
  • Dan Webster
    Dan Webster Aug 24, 2010
    thermopile thermophile hell I can't spell. Anyway you can order that part at Partstown
  • Dan Webster
    According to my spell check thermophile is the correct spelling. HaHa. Dang computers. The thermophile does double duty. It holds the safety magnet open AND it operates the gas valve. As the demand for heat is called for the thermostat completes the circuit to the gas valve solenoid. When the thermophile gets weak and gas is called for the whole thang simply dies.
    Thanks for this, I will definately try to get this part. You have been a great help.
  • Dan Webster
    Dan Webster Aug 27, 2010
    Thanks
  • Dan Webster
    I could use some onion rings right now. LOL
  • kowgie Aug 27, 2010
    i got the thermopile yesterday, and fitted it last night - guess what??? We are back in business!!!!! As soon as it was fitted you could hear the connection kick in. Now we can fry baby fry!!! LOL Thanks Again.
  • Dan Webster
    Thanks, Did a bit of frying meself. Glad you could git er done!!! LOL
I need a new drain valve for American Range fryer. Where can I order one, and what size is it?
American Range part number A80201. It's an NFS approved stainless ball valve, generally 1.25". If you Google American Range A80201 you can find it on line for less than $70. You must use an NSF approved valve to comply with health codes.
Sep 07, 2014 | American Range AF40 Deep Fryer
Help flames front of fryer
Hi there.
Try to check and clean if needed the fire tubes, soot may have build up inside blocking the flame path. Soot build up on fire tubes and burners are caused primarily by low gas pressure, assuming that the orifice size are correct with respect to the type of gas used.
Regards.
Sep 03, 2013 | American Range Kitchen Appliances - Others
I need an owners manual for an american range fryer
You could go to the website www.americanrange.com and request one...
Susan
Restaurant Equipment Outlet
Cincinnati, Oh
888-542-5959
Oct 16, 2011 | American Range AF40 Deep Fryer
Where can i buy the burner orifice to my fryer american range model af40 thanks
Hi there.
Try visiting http://www.americanrange.com , you will be able to locate there the nearest parts and service dealer in your area.
Regards.
Aug 16, 2011 | American Range AF40 Deep Fryer
Turn on the pilot , when turn on the burnes evreting off
Hi there.
Ensure that the gas supply pressure is sufficient and the thermopile should be free of soot or any form of dirt, also the pilot flame should heat up the thermopile efficiently.
Regards.
Jul 12, 2011 | American Range AF40 Deep Fryer
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
This has a Robert Shaw gas valve, the pilot light lights but when you let the button up it goes out no matter how long I hold it down
The power pile thermocouple has gone bad and needs to be replaced.... that is what sends power back to the gas valve to hold it on...
heatman101
Nov 07, 2010 | American Range AF40 Deep Fryer
AF 40 MODEL WON'T STAY LIT AFTER LIGHTING
You need the replace the thermocouple which on them is called a power pile generator.
you can buy it right here
heatman101
Sep 20, 2010 | American Range AF40 Deep Fryer
American Range AF40 Deep Fryer Logo
206 people viewed this question
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Mike
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
