That could be the compressor relay. With age they will tend to fall apartThe fan motor by the compressor is what I would next check. It dies and the cooling will suffer. Give it a hoovering while you are poking around under there. If all of that turns out to be kosher I would look for ice and frost on the backsides of the freezer. That is a sure sign of a defroWe have a whirlpool side - 279675c.jpgimg src="/uploads/images/279675c.jpg" alt="279675c.jpg" class="h_mi" />Look for a swollen defrost terminator. It kills the circuit to the coils when it gets warm enough to melt the frost which is 50f. It is supposed to have continuity when the temp reaches around 25f. Check it for swelling, aWe have a whirlpool side - 3212752.jpgway (no pun intended LOL) You can sometimes get a tech sheet at this link if you have your complete model number
Service Matters
Here is a stash of manuals
The hot to the touch is a sure sign of dirty coils below. Give it a good cleaning downstairs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
