Question about Janome Memory Craft 10000
How do I get the thread spools to pop back up out of the sewing machine?
  • 340 Answers
Is it an MC10000?
Have a look at this manual on page 14.
http://www.janome.com/documents/File/ManualFile/MC10000.pdf
Posted on Aug 25, 2010
HOW DO YOU WIND A BOBBIN ON A PFAFF 2022 SEWING MACHINE
Bobbin winding
1. Place the thread spool on the spool pin in
against the spool.
back to front. Pull the thread clockwise around
the inside to the outside.
4. Place an empty bobbin on the bobbin spindle.
5. Push the bobbin lever to the right to wind.
A pop-up appears on the screen to inform
you that bobbin winding is on. Press the
foot control or the start/stop button to start
winding the bobbin.
When the bobbin is full, the bobbin winding
will slow down and stop automatically. The
pop-up closes. Remove the bobbin and cut the thread
Sep 14, 2016 | PfaFF Sewing Machines
How do I use the double needle
first you take out the single needle, then you insert the double needle the same way you would the regular needle
the flat side goes toward the back of the machine inserted all the way up into the needle holder
then you take the 2 spools of thread & put them on the spool holders
then you thread the machine with the first spool just like when your going to sew normally with one needle & then you thread the first needle
& then the second spool is threaded the same path as the other spool,, ever guide & then you thread the second needle
then you make sure you have thread tails for top & bobbin thread of 3 to 6 inches long, pulled toward the back of the machine before you start to sew
happy sewing
Sep 05, 2011 | Brother XL-2610
How do you swing the second bobbin holder up and place "one bobbin on each of the bobbin holders"? I have a 7570
I presume you want to twin needle sew?
So you need to have two thread spools on pins to do this. Most machines will have two spool pins at the back for this purpose, sometimes they are retractable pins so you would just need to pull the second one up.
or sometimes a seperate pin in the accessory box that you can mount onto a hole somewhere for this purpose.
Rather than buy two reels of thread in the same colour to twin needle sew, you could also wind a second bobbin off (only half full should be plenty), then pop this onto one of the pins and the main thread spool on the other.
Hope this helps you out, I couldn't actually find an image of the back area of this model but most quality machines have two pins as standard.
Apr 15, 2011 | PfaFF Creative 7570
My dad has just bought a second hand elna lotus sp sewing mashine and does not know how to get the spool out can you please help him he said it has type 35 on it
Look in the back. By the lever you will see a white knob on a spring. Pull this down, put it in the bobbin; lift out. This is the bobbin take out method. Hope this helps. Keep this machine. It is great and only increases in value.
Nov 16, 2010 | Elna Sewing Machines
I havea 6000 emb machine. it breaks thread bad.just knots the end of the thread
check to see if the thread is catching on anything like
spool pin
notch on spool itself
sometimes thread comes off the thread take up lever-on some machine
check thread tension
check neelde to see if it's bent-roll on flat surface to see if it rolls correctly
if when sewing the is a popping sound when the needle goes thru the fabric the needle is blunt
check for lint & thread in bobbin case area
Sep 23, 2010 | Brother Sewing Machines
Hi why does the machine skip stitch ,or Cather at the bottom ,the problem occur while am sewing.
check to see if your needle is bent-roll on flat surface to see if it roll good
if the needle make a popping sound when going thru fabric it is blunt
the needle is incorrectly inserted in needle clamp holder
needle & thread not compatable with project
check for warped bobbin
rethread machine
check bobbin area for lint or loose threads
check to make sure thread is not caught on any thing-such as spool pin-notch in spool of thread
Aug 22, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
How do I thread the machine
Raise the presser foot.
Place the thread spool on the spool pin so the thread feeds from the back of the spool.
Place spool cap against the thread spool.
Take the thread across to the first guide, then down the first slot, back up the next to catch the uptake lever, then down to the needle.
At the top of the needle there should be a metal "hook" that helps hold the thread close to the needle.
I found a download for the manual at this site for $5.00 - http://www.mastersewusa.com/infos_132Q_Featherweight.html
Apr 02, 2010 | Singer Featherweight 132Q Mechanical...
How do I replace a broken spool pin on the Brother Innovis 30 sewing machine?
If the spool pops in, you may be able to find a replacement where sewing machine parts are sold.
If it was a molded to a platform, a thread stand may be a less expensive method to use. You can find a single cone thread stand with sewing notions.
http://www.sewingmachine221sale.bizland.com/store/page24.html/
Mar 29, 2010 | Brother Sewing Machines
My prdect is fashionaire 2380.when i'm sew somthing it's break the thread,and it's stack
Check the thread spool to see if there is a nick where the thread is catching. If there is, you can smooth away the nick with an emery board, or just flip the spool so the thread is feeding from the bottom of the spool.
Sometimes the thread feeds too quickly from the spool and puddles around the spool pin. A thread net (can be purchased online or at a sewing machine dealer) can eliminate this.
Check the threading to be sure it is correct - always thread to top thread with the presser foot up.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Refer to your manual for threading and bobbin position.
Feb 20, 2010 | White Sewing Fashionaire Sewing 2380...
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
