Question about Kenwood KS-706HT System
Subwoofer POPs when a certain frequency is received is there a fix?
It says frequency response as 40 Hz to 170 Hz (Subwoofer) and 200 Hz to 20 KHz (Satellite speaker). How it will manage frequency from 170 Hz to 200 Hz. Will this be affected
The sub-woofer will handle a frequency of 40Hz to 170Hz of the sound spectrum, and the satellite will handle 200Hz to 20KHz. There is frequency hollow that is, 170Hz to 200Hz; and it is not quite audible and noticeable to human ear. Gopakumar Gopalan Google
Apr 22, 2014 | Audio Players & Recorders
How to Connect HT-CN300 Subwoofer to Onkyo TX-SR313?
Hello! You will most likely need a RCA cable with single ends (both being male ends) One end plugs into your subwoofer input....marked subwoofer input on the subwoofer..........The other end will plug into your receiver that is marked subwoofer . When low frequencys from your media.....whether dvd,s /cable or audio cd,s is present the sub woofer will kick in , Make shure to adjust your setting on the rear of the sub if it has any like volume or frequency , most better subs have them as where the home theater in a box combo usually does not!
Jan 01, 2014 | Sharp HT-CN300 System
I have an Onkyo sr-605 receiver and a ksw-10 subwoofer hooked up to the subwoofer pre-out on the receiver. I have the subwoofer on auto so that it will pick up low frequency and turn on. It usually picks...
I have encountered this problem with other subs. The input has to reach a certain level before it abruptly switches on. I found the effect so annoying that I changed to another sub.
Apr 03, 2017 | Audio Players & Recorders
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
Subwoofer does not kick in during stereo mode with front speakers
There should be an adjustment in setup that for 2 channel sources, you may have to enable the subwoofer output. Or alternatively, if the subwoofer output for 2 channel sources is in fact enabled, then increase the crossover frequency for the sub.
May 07, 2009 | Audio Players & Recorders
Cant get sub to work
It sounds like maybe you need to tell the receiver about the Sub so it will route Low Frequencies there.
Go into Speaker Setup (SP SYS/SETUP Button near upper right side of Op Panel) and follow the prompts.
The parameter we're most interested in is the question "Subwoofer Yes" or "No".
Some guidance when selecting speaker parameters for the rest of the channels:
SMALL vs LARGE: This has nothing to do with size so much as it deals with the BASS handling capacity of the speakers. If you say SMALL, most low frequencies from those channels will be re-routed from them to the Subwoofer. If you say LARGE the channels will still get the low frequencies they deserve.
Even if you have all LARGE speakers defined the Sub will still have work to do as it will be dealt the LFE (Low Frequency Effects) from encoded movies and all or most of the content below certain frequencies.
Apr 08, 2009 | Onkyo TX-DS575 Receiver
Woofer assistance
You need to buy an active (self-amplified) subwoofer. Attach it to the Subwoofer Preout connector.
I imagine you would be able to answer LARGE for all of your speakers.
Mar 27, 2009 | Onkyo TX-DS575 Receiver
Sleep mode
It will power off if the frequency range of the signal being sent to it is set too low, or the amplitude of the signal is too low as well.
Try increasing the subwoofer crossover frequency and/or increase the gain from the LFE/SUB of the receiver/preamp you have it connected to. Also make sure that in the setup menus of ALL of your components have an LFE channel enabled such as by selecting the output of source material of your DVD player for example, to output 5.1. Otherwise, it will not send a signal for the subwoofer to play, nor will it play the signal if the crossover frequency is set too low.
Example; the setting on your DVD player setup menu is set to two channel: result with only one exception, subwoofer will not play
Example; subwoofer/LFE level on receiver/preamp set to -10dB and/or subwoofer volume too low. Result: subwoofer will not play.
Example; subwoofer crossover point set at 35Hz. Source material playing sound at 30Hz and lower. Result: subwoofer will not play.
Nov 23, 2008 | JBL PB10 Subwoofer
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Subwoofer
set your front left and right speakers to small
Mar 28, 2007 | Denon AVR-3806 Receiver
Kenwood KS-706HT System Logo
24 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
