Question about Iomega StorCenter (33349)
I keep losing the device every 30 seconds. the network is connected to a Gbps network
    Sergeant:
  • 223 Answers
Try changing the network cable, these are infamous having 16 points of failure in every cable. I find this especially true in my Gbps networks, crappy cables. Hope that helps! cheers. Next I'd look into your router/hub/switch. I have had many of these fail too after a couple years. Third, I'd try slowing my network to 100Mbps instead of auto in the network adapter properties under the speed heading. sometimes slowing it seems to solve lost packets. (which could be due to a bad wire) Hop that helps Also try simply moving the device closer to the router if its a wireless device, or change transmit channel on the router config, Noise can be introduced in a number of ways these days. cheers.
Posted on Aug 24, 2010
Is there any cheap dedicated server host?
There are many servers available which provide you good quality servers as well as having the best bandwidth. I would suggest you use unmetered bandwidth. It has super fast networks and provides servers with 1 Gbps, 2 Gbps or 10 Gbps. They use latest enterprise grade hardware from the super micro. It would be the perfect server for using the internet for less bandwidth.
pros-and-cons-of-dedicated-servers---is-a-dedicated-server-for-me-sjy1iz5kqux1vezlah5xlhqp-4-0.jpg
Jan 13, 2018 | Computers & Internet
Trendnet TU3H4 USB3.0 Hub does not work in windows 8. Device manager says it is (not functional)
HelloI have the same problem!I have a message to the support
https://www.trendnet.com/asp/helpdesk/
Kind regards
Feb 03, 2013 | Trendnet Tu3H4 4Port Usb 30 Hub External...
My network card is only allowing 54mbps , I have 1.5gig dsl with a 300mbps router Do i need a new network card the driver is updated to last update
Your wireless network card is more than sufficient to handle the bandwidth provided by your DSL connection. A "1.5" DSL connection refers to a 1.5Mbps DSL line. Your network card is an 802.11G network card. Simply put, your network card will only run at a maximum of 54Mbps, far short of your 802.11N router's maximum speed, but provides more than enough room for the bandwidth provided by your Internet Service Provider. Gigabit connections (connections with speeds measured in 'Gbps') are almost exclusively for private networks or corporate networks with Fiber Optic connections.
In layman's terms, you can get a newer network card for your computer that will improve the speeds between your laptop and any other computers on your network, but as long as your network card is supported by any modern operating system, odds are it is able to transfer data fast enough to keep up with your DSL connection
Nov 25, 2010 | Toshiba PA3235U-3BTM Network Adapter
I keep losing connectuin to xbox live
if you unplugged your modem it probably changed your ip, that happens to me alot lol. and if you have a from from the xbox to the network, that means your connection is wrong. make sure that the ethernet cable is connected from your xbox 360 and modem, then try again.
Dec 09, 2009 | Microsoft Xbox 360 Elite Console
Network
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 16, 2009 | Toshiba Satellite Pro L300 Notebook
Wireless will not connect Wireless network shows all 5 bars but will not connect I have upgraded the Intel Pro/Wireless 2200BG from the Tosiba site and flashed the BIOS per the Tosiba site, but it still...
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Oct 03, 2009 | Toshiba Satellite M45-S331 Notebook
Internet explorer cant connect to internet.wireless connection is connected
Windows WiFi Fix,
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Sep 29, 2009 | ASUS Eee 4G Notebook
I cannot get my Netbook to connect to my wireless network. I have 3 other devices that connect just fine. What am I doing wrong?
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Sep 24, 2009 | HP Mini 1000 Netbook
Math
Product Details function pw(s){pop('/xWI?lid=1&fid=96292&aid='+s)} Product MPN MPN pci-dda08/12 Key Features Data Transfer Rate 1 Gbps Form Factor Plug-in Card Interface PCI Connectivity Wired Platform PC Package Qty. 1 Protocols Data Link Protocol Gigabit Ethernet Other Features Cabling Type Ethernet 1000Base-TX Miscellaneous Product ID 21195495
Feb 13, 2008 | Intel PCI-DDA08/12 Measurement
Iomega StorCenter  (33349) Logo
364 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
